anniversary buff for leg drop rates will be a permanent change
Rift fragment drops will return to normal
source: http://us.battle.net/d3/en/forum/topic/12926172697#1
So i got a new toy today (Golden Flense) and got a pretty badass roll on it.
http://us.battle.net/d3/en/profile/Bucknaked-1438/hero/45647983
It came with max wrath restore (4), 3.70 wrath per second on it, +max wrath, and high-end max damage. So between those, my near perfect cindercoat, and resource reduction from paragon points I can spam Sweep Attack - Blazing Sweep indefinitely even versus a single target. Also, since it actually costs wrath instead of removing the cost (i.e. Foote) it actually procs Wrathful's healing.
So since Sweep Attack is now both my generator and spender (or pure generator if I use Righteousness) should I slot in another spender or just use another utility spell? I can't really think of what to use as a spender but it seems sort of wasteful to just sit there with a full wrath bar as well. Anyone have any experience with a Golden Flense build?
Since you want to be spamming Sweep I'd think that stopping to spam something else would be counterproductive unless that spender was far more powerful. I'd try working in something like Condemn (Reciprocate), Heaven's Fury (no fire runes though), or perhaps Shield Glare (Devine Verdict) for the extra 20%.
Other than that, Heaven's Tempest is probably what you should stick with since it procs Fire Starter well and shouldn't really interrupt the flow of combat.
Popped a rift guardian solo on t5 on my sader in under 10 seconds. No conduit.
Ocellaris once you get Zuni set (assuming you haven't) your fetishes will do pretty well. Are you wearing a MoJ as well? Tasker and Theo helps IMMENSELY
Was it the Stonesinger? That guy doesn't countThat is pretty awesome though.
But dat 2900 dmg doe...
Still trying to get my last 2 Akkahn pieces dang it... =(
What's the normal damage and defense for a crusader? I think I'm at 239k damage and 8mil defense right now. Should I be trying to substitute some defense for more damage?
239k damage at level 70? That's not normal for any class. That's super low. About 8-10 mill toughness for 1 hander sader and around 7-800k. 2 hand sader should be 12-15 mill toughness and 900k to 1 mill.
This is not using the block passives. Block saders are a very specific build that few people play.
239k was maybe okay pre RoS. That's like using a level 60 weapon all the way to 70.My monk before paragon update was at 330k unbuffed.
Should get a few hundred thousand more damage just upgrading weapon alone. Don't worry too much about crafting jewelry. What you can do is craft the sets. Born and Captain's sets are amazing to hold you over until you find Akkahn set pieces. These sets provide 10% cooldown reduction each and some other bonuses. Aughild is also good because it gives 15% elite damage and 15% elite damage reduction. Asheara is nice for 100 resist and 20% life. Blackthornes...I know, people love to hate on Blackthorne, but as a placeholder until you find Akkahn again, it's good because of 10% elite damage.
IF you have a Ring of Royal Grandeur, which at this point probably sounds like you don't, you can wear 4 sets on Crusader. Born, Captain, Asheara, and Aughild. This is due to the ring letting you get by without having all set items equipped. In fact it removes the set piece requirement by 1, but you have to have a minimum of 2 set pieces equipped. So when I said you can wear 4 sets, it's 2 of each of the ones I listed.
Aughild hat/bracers, Captain's pants/belt, Born shoulders/chest, Asheara gloves/boots. I wore those for many many paragon levels on my crusader until I found Akkahn.
BTW, cool down reduction is the most important stat on crusader.
*sigh* oh well.
I just got Akkahn pants yesterday through the shard lady
Cool down reduction is the most important stat on a crusader? Whelp, I didn't know that. I actually think I traded the cool down stat on the pants for 2 gem slots......
239k is low, but there is no normal without a frame of reference (how long have you been at 70? What difficulty? Paragon level?)... 1 mill profile dps puts you in the top 1500 Crusaders...
239k is just easily upgradable with a few tweaks and/or crafted rares/rerolls.
Could you guys critique my monk? I'm a lvl 70 and only hitting 270k sheet DPS. I'd love to hear from anyone that know what they're doing.
http://us.battle.net/d3/en/profile/Opie-1667/hero/40636849
I'm using it. Fire dog crits for 5-6m for fire damage, and 40m+ attack crits. It's like having a permanent lower level gargantuan hanging around.Have any of you WD used the tall mans finger ring? I must say, I was worried about having less dogs on the field for agro reasons, but damn. That single dog is extremely powerful. I don't have much decent gear and the dog is getting silly crits. Anyone else experience this ring?
http://us.battle.net/d3/en/profile/ob12-1797/hero/40656140
