jcvjcvjcvjcv
- Sep 28, 2007
Has anyone determined who makes the panel for this monitor? Samsung or LG? Maybe even Sharp?
Does Samsung still make 30" 2560x1600 panels? I thought they quit that business some time ago.
I just got my U3011 -- yes, U3011 --- from Amazon for 1099 USD + sales tax and set it up an hour ago. No dead or stuck pixels as far as I can tell with UDPixel. The screen looked huge at first, but when I got to the desktop ,the feeling of screen real estate isn't at all too much. It feels fairly natural -- like you moved into a bigger home.
There is a smell -- I hope that's temporary "breaking in" period.
The black level is MUCH blacker than my HP ZR24W, on which black has a blueish-grey glow. The heat generated doesn't feel greater than my 24" monitor when I put my hand up to it.
The screen is sparkly, though, but the matte matches exactly my ZR24W.
I wanted the U3014, but the semi-gloss and IPS edges glow were question marks at the time, and the consumer reviews weren't completely in, and those posted were mixed.
The text seems a bit small, and seems as if it fades melts into the background - i suppose that's the coating -- maybe I can experiment with the size.
I hope I made the right choice, though I wish I had both monitors side by side to compare myself directly to choose the one I prefer better.
You mean that glorius electronic silicon smell of newness? You only get that once.
See for me with 2 U3011s, having a third U3011 just pleases my OCD and as well can open to Surround gaming if I want to attempt it... ...heaven knows I have enough steam games to try.
All of them dissapear if I move the head to the center of the glow focus, the one that costs more to make dissapear by centering the head is the top-left corner (that one might be a bit of bleed, but I see it's looking pretty similar to your pics).
From your description and your photos, the top left corners seems to have 2 spots that are bleeding. the rest seems like IPS glow.
Information on Rev A02!! Scroll up a couple posts
http://en.community.dell.com/support-forums/peripherals/f/3529/t/19507654.aspx
RTC overdrive on light backgrounds
* This is by design and will not be addressed
...until Dell iron out all the issues from this monitor.
...even if you managed to get a good panel, (no dead, bright pixels, no bleeding), there will still be other annoying things such as IPS glow...
How long roughly will it take Dell to fix the big problems: the grid line issue and the "IPS glow" in the lower corners issue?![]()
