jonneymendoza
- Sep 11, 2004
i got the monitor and WOW this is amazing! no dead pixels no banding issues, no tint issues, nothing. its perfect!
Sooooo.... What do you think of the monitor?![]()
Mine suffers from severe IPS Glow. On dark backgrounds (like in Lightroom, Photoshop elements 10, Steam interface... or this forum), it is impossible to have a normal black color when there is a view angle.
Colors on my U3014 are so good I can tell the difference when I send a window on either of my U3011.
If you didn't buy it directly from Dell I would say you got screwed.
My sticker is definitely original, there's nothing under it, and it has that holographic feel on the silver text.
My guess is the seller had a Rev 01 but wanted to get rid of his and put up a sticker on top of it.
Try removing the sticker and see what's under it?
Unless you sit at least 121.92cm/4ft away this is normal for 30" IPS. Turning down the brightness helps. 30" glow vs. 27" from 76.2cm/2.5ft.
But if it is normal, I suppose that all 30" IPS are like this ? How users can bear such a drawback ? They never display dark photos or dark backgrounds ? Or they perhaps live with this ?
For me, the right corner is the worse.
Finally, concerning your link, it seems that 30" monitors has the problem and 27" not, right?
So a 27" such as U2713H or HM should be a better choice for me then?
Anyone know why my u3014 shows up as an audio device even though there's no speakers?
