The image retention would be a dealbreaker for me. I'd definitely check to make sure the problem doesn't persist with your replacement. This issue is often related to the panel part, usually caused by excessive voltage creating a persistent charge which remains on the affected pixels. If the wrong value is in the spec, then, unfortunately, all of them are going to have it.@soldierblue thanks, the burn-in seems to be gone for now. It may or may not come back after a break, but I'm not waiting around to find out. I'm sending it back today and hopefully the replacement will be better.
And this can become permanent. I've got an LCD TV (S-PVA) that has ghost images from black bars permanently imprinted on either side as well as an accumulated overall halo from other images that are completely non-static.
This issue bothers me, because I was actually considering this monitor. It's one of those things that never seems to be fixed, or even acknowledged by the manufacturer as a problem, because it would be too costly to discard such a large existing inventory.
