http://accessories.dell.com/sna/pro...l.aspx?c=ca&l=en&s=dhs&cs=cadhs1&sku=224-8284
the monitor is on sale again, 779 cnd.
price is a main factor for me, but if there was a 30" for this price id obviously opt for that. the res wont be too off from a 30", there is only 160 pixel difference between this dell @ 2560x1440 and your standard 30" @ 2560x1600. i cant justify the price difference, for 160 pixels... i personally was going to get the HP zr30w because the u2711 at regular price was about the same... but the fact that this u2711 is on sale for 470 bucks off for like today, and maybe tomorrow only i pulled the trigger..
all prices equal, i think the HP zr30w is a great 30" and priced well, just personally i couldnt justify the $500-600 difference for 160 pixels. for you i think id go 30" because this u2711 isnt this cheap on the dell.com site (assuming your from the states)
edit: if you are planning to run an 8800gtx @ that kinda res, im not sure how well it will run. may need a better video card for res 1920x1200+. i dont think the 768mem on the video card is sufficient for high res gaming
The sale is over.I just checked the link, and it is $1,249 CDN. Am I missing something?
Keep in mind that the 30" has 409,600 more pixels than the 27". Or: the 27" is 3.7MP, and the 30" is 4.1MP. Also, the U3011 has a 10-bit panel. The 10-bit panel doesn't mean much if you're just gaming, but for professional work or if you plan to calibrate it's very nice to have...
Only 160 pixels vertical?The extra real estate is nice but in reality its only an extra 160 pixels vertical. It doesn't matter how many thousands of pixels that means, it is still a visual sliver.
Celerator, Dell has sales like that _regularly_. Their 30" $2000 monitor is actually $1400 every other week or so. No one in their right mind buys anything from Dell for full price, because it's 25%+ more than the promotional price you see all the time.
Hong Kong Dell is selling U2711 at HK$4,699, that is US$602. Should I get one at this price?
Then 1920x1200 is "only" 120 more pixels vertical than 1080p. And 1080p, something you'll find on 24" LCDs these days, is "only" 280 more pixels vertical than 1280x800, a low resolution for cheap 13" laptops.
Also, 2560x1440 is only 240 more vertical than 1920x1200.
1920x1200 vs 1920x1080 is also 11% vertical difference; yet so many people are looking for x1200 monitors over 1080p ones.It's all about ratio. Counting pixels is not the same thing.
1920x1200 vs 1280vs800 = 37% vertical increase
2560x1600 vs 2560vs1440 = 11% vertical increase
20% or better is getting in the range of a big enough of a visual difference to be meaningful. 11% is barely noticeable. Yes it is a visual sliver. Don't really see why that would be debatable.When you factor in the price difference it for that visual sliver the value proposition just doesn't seem worth it.
Just received it today. Seems like a good upgrade from 2405fpw. Hong Kong's U2711 is indeed Made in China.
Color is a bit bluish, tho... What color settings are you guys using?
MAKE SURE that you can live with the Antiglare coating. For some of us, the sparkles have gotten unbearable. If you don't return the monitor in the specified time, Dell will not do anything for you. (and they aren't obligated to do so). If you even so much as notice this coating when you get the monitor and think you might not be able to deal with the coating over time, you should exercise your right to return it. Remember at this price you are paying for a premium product. Don't be regretful months later.
Personally having had the monitor since March I am in that boat of regretful. That coating interferes with text in certain color ranges and makes using the monitor next to impossible in some situations. I'm afraid I can't recommend this as anything more than a defective monitor and that folks should avoid it.
