> 90% of all halfway current games offer every resolution that is currently available in windows.I haven't played games for the last two years but I don't think there will be an option now for 2560x1440 right?
I just received my U2711 from Dell and have a problem I haven't seen mentioned: When displaying a solid white image on 2/3 or more of the screen, the monitor emits a faint high-pitch whine.
Also, when the monitor enters power-save mode, there is another, slightly louder, high-pitch whine. When the monitor is off, it also emits the whine, although slightly quieter than when in power-save mode. Disconnecting the power cable with the monitor turned off causes the whine to ascend in pitch over the course of about a second, then stop. I assume this sound is being emitted by the power supply, and the ascending pitch just before stopping is the power supply discharging.
Is this normal and has anyone else with this monitor experienced a similar issue? Will it stop after some use? Should I contact Dell regarding a warranty replacement?
Edit: I spoke with a Dell service rep via chat and he kept trying to blame it on my video card or PC's PSU. I fail to see how the input device would have any effect on a sound emitted by the monitor in power save mode or when turned completely off.
Additional info and troubleshooting steps I've tried so far:
The monitor (and pc) are connected to an APC battery backup that is less than 1 year old and operating below 50% load.
I powered the monitor off, then unplugged it and reconnected it a couple times (at both ends) when testing earlier - this is how I discovered the briefly ascending pitch when disconnecting the power cable before the whine stopped
I also tried moving the power cable from a battery-backed outlet on the UPS to a surge-only outlet, and back. Each time it produced the same behavior.
When I get home, I also plan to try using a different power cable that I have laying around. I will probably also try bypassing the UPS, just to make sure.
Does it make the noise when not connected to the pc? Also try a different outlet in your house that is on a different circuit to see if the noise goes away to rule out electrical noise. Most likely dell needs to replace it.
For those of you, who hate the Anti Glare coating of the U2711, check out this glossy U2711 of mine:
http://farm2.static.flickr.com/1271/4672028261_2ffa274797.jpg
This is my U2711 next to an iMac. You can clearly see the reflection of the iMac on the U2711's surface.
This was done by disassembling the unit, and 'surgically' removing that annoying AG coating.
For more images (disassembled U2711, removal of the AG, and before/after pictures) check out this flickr page:
http://www.flickr.com/photos/42236618@N07/tags/u2711/
For the AG removal idea, credit goes to djdude1010, and the LumenLab forum's brave pioneers.
Not completely useless to someone who will only ever use it via displayport. Personally, I think a single input / type does reduces the value and utility of this monitor.Yeah there is but lack of other connectivity options makes it completly useless.
now i have seen a LOT of people complaining about the anti glare coating, my question is: is it really that bad? and is it different from the matte screens found on most TN panels?
It is a fairly petty complaint. Most people at home would prefer to take a softer coating, like on some PVA panels, but there are more important things to concern yourself about, like actual performance.
It is a somewhat petty complaint but we don't all think the same. For some, the graininess of the monitor is simply intolerable and can't be ignored no matter how much they try to ignore it. For others like me, I noticed it at first when I looked for it but after that it's basically out of sight out of mind.
I do agree that the constant complaining on the forums is a bit excessive. Yes, the AG coating is fairly common place for monitors now. Yes, it sucks for people that are annoyed by it. No, complaining about it on the forums every single time a display is the topic won't change the manufacturers' minds. </rant>
On the other hand, the brain is very susceptible to bias. I wonder how many people that are complaining about it wouldn't have even noticed the anti glare coating if people weren't posting about it?
Would I be able to get 2560 x 1440 working with a normal HDMI Cable?
...I do agree that the constant complaining on the forums is a bit excessive ...
No it is not. The sparkly AG grain is only on IPS displays. And all IPS displays are manufactured by LG using the same coating.so basically its the same anti glare i have on my crappy tn samsung monitor then?
2233rz is a TN panel. I haven't seen it but TN panels do not have the sparkly grain type of coating. They have a symmetrical raster (like a mosquito net pattern) which is more noticeable on monitors with higher dot pitch. In your case you are more sensitive to that TN pattern than the grain.That not true, the AG on my 2233rz was horrible, worse than my u2410.
2233rz is a TN panel. I haven't seen it but TN panels do not have the sparkly grain type of coating. They have a symmetrical raster (like a mosquito net pattern) which is more noticeable on monitors with higher dot pitch. In your case you are more sensitive to that TN pattern than the grain.![]()
evilssofa, what about using a hdmi cable instead of the dvi cable, on my 470 with one hdmi port? will the colors be better and everything else??
The u2711 is limited to 1920x1080 over HDMI (see the [ it will not do 2560x1440 over HDMI regardless of the version or quality of your cable or video card, which is a really unfortunate choice by Dell.
so dvi is better than hdmi!? that's good to know. thanks.
I have two u2711's and I would like to plug them into my mac pro 5870 graphics card that has two mini-displayports.
Could I get a cable that goes from displayport to mini-displayport?
I've dealt with the dvi-d to mini-displayport adapters before and have been dissatisfied with the inconsistent performance. i'd rather just go from DP to mini-DP with one cable.
My apologies if this has been covered earlier. It's late and I'm too tired to look.
As a new U2711 userer, I've been pretty much delighted with it. Such and amazing picture on this thing. I find for FPS games it's a little laggy, but my previous display was a CRT, so I was pretty much expecting a bit of a step down in response. It would however still be nice to improve it. Are there any tricks to reducing it's latency at all?
My major gripe right now is sometimes the monitor doesn't seem to realize it's getting signal after I reboot. It goes into power saving mode and doesn't seem to want to wake from it. Sometimes, I can turn it off and then back on again, and it works, other times it's like nothing will wake it. I have same issuen when trying to get into my bios, it just doesn't seem to recognise it's getting signal.
Anybody with insight as to what is going wrong here?
It's hooked up to a XFX 5970 Black Edition via the included dual link DVI cable.
Thanks
guys, i have been starring at this monitor too long to tell, but does anyone else think the white with my monitor seems slightly pinkish?
