firehurricane
- Oct 16, 2011
too slow for games, specially evident ghostings with Deus ex
ridicolous.
ridicolous.
ridicolous.
There is no input lag (1.1ms check PRAD.de) when measured properly.
Have you considered the Asus PA238Q instead? It costs less and has better factory calibrated colors, no input lag+ fast response times. PRAD.de rates it higher than the Dell for gaming and overall.
Colors look better due to calibration so consider the better image quality+slightly better gaming performance. In Canada the Asus is 40$ less (280 vs 320).
I use the 2009 MixAmp with Denon D2000's for everything, no complaints given the pricing of the AMP. You can get all in 1 headset solutions for a bit more than the AMP by itself from Tritton and Turtlebeach.
Both panels have no input lag, the Asus has slightly less ghosting (just checked both PRAD.de reviews) but unless you are used to a fast TN you probably won't notice.
Deciding between headsets is going to be hard, best to find people who have owned multiple sets rather than listening to people saying "I have X headset and love it" but have no experience with other models.
You can always use the 360's RCA Audio Cable+this to hook up to some decent 100$ speakers
Masturshake..
did u get those Dell monitors??? if yes can u give some comments abut them?
how does they work with SF???
Sorry for the late response works perfect i was able to emulate the same input times i put in while at my local arcade / lan... This is the way to go if you want Lagless IPS monitors... fellow street fighter fan by chance?
Yeah, but i myself play tekken... how did u connect to your conosle? hdmi-dvi converter?? did u by chance notice any ghosting/blur in SF?
Dell Canada U2312HM on sale for $219.99 in Canada today.
Wow
http://accessories.dell.com/sna/pro...=77903&acd=CAqD7bLWUPI-NE9uxSgi5RgLGq0GQ8YZmA
Wow
Can you share the coupon code you used?
Sure. The coupon code for the 15$ rebate is L07TXSDW2NRR0H. I saw it on Dell Website. The other 100$ was an instant-rebate but it doesn't seem to be offered now.
No buzzing here at any brightness.
Thank you i will now be pulling the trigger on both of these, QQ anyone with an console hooked up to these what is your solution for audio? Was thinking i would have to get an astro mixamp to get audio from my xbox since there is no audio out but 100$ is pretty pricey
for someone who wants to buy a new monitor right now, would you suggest this or the U2311H?
I bought the u2311h 6 months ago. Was going to buy another 2 for eyefinity, but noticed that they are replaced with the u2312hm. This will be my first eyefinity setup so If i purchase these, will there be problems such as bezel correction etc.
two totally different monitors and bezels so yes, there would be compatibility issues with bezel correction (I think)
How so? You manually adjust the bezel correction, no?
I don't think that's IPS glow. IPS glow on these monitors is white shimmering from a heavy angle.
