Looks great but i'm not sure how much of a difference there is between 1080p on 24inch and on 27inch monitor. Is there any comparison pic out there?
By the way, this Dell is 10 bits or 8?
Frameless
IPS glow is what I get after drinking a couple of brewskis.![]()
I never saw it when I checked the monitor under normal daytime hours or at night when I had some lights on. The fact that I had to sit in total darkness and edge my way to the side to the monitor to see, seems pretty senseless. But I understand the need to want to know.
Every monitor I've had or dealt with, has had issues of some kind, you quickly learn to forget about it, it's just inherent to the technology for now. Your brain just adapts to it after a while and you soon forget what the hell you looking at in the first place.
It's like back light bleeding and ips glow, all monitors have it to some degree. You just get the best monitor you can afford, and go on with your life. There will be better ones tomorrow, and some people will wait til tomorrow, or next month...or maybe next year.
You think monitors are endless points of discussion?....you should spend some time in the photog forums....omg....it's nauseating.
Anyways, have a great day....hopefully I've been of some help!!
Cheers,
-Scorp out
Just got my S2740L, videos+pictures coming tonight.
It is indeed more reflective than a regular glossy display. Once set up to my CrossOver 2720MDP (12-14 ms of input lag) I instantly noticed the complete lack of input lag on the Dell.
The Stand really sucks though since it only tilts and the display itself sits only 4 inches/10cm above my desk. The top of an IPS displays bezel should line up with the top of ones head to reduce glow. It needs to sit 4 inches/10cm higher to match the top of my head, so I have it on top of a Corsair H50 box.
Its perfect for gaming. I play BF3 and Skyrim on it and it has no input lag no ghosting its very very good at gaming..
Actually I ended up keeping my displayThe first one I had, it had a few scratches on it so I had it replaced. I can try that when I get home from work. But I'm sure once NCX posts his video it will be very very informative, which should be posted any time now..
