Is there any other way than using a camera to check if my monitor has PWM ? If it does then it's not a problem for me, but I want to be sure before buying the S2440L. The monitor I'm talking about is LG W2284F (LCD).
are your whites/greys in LG slightly yellow? if so then you have the same panel as in my hp 22". yup camera high shutter speed (sports mode) is the easiest way to check for pwm.
Just took a video (with my phone, iso set to 400) of my monitor and I can clearly see those horizontal lines going up and down. It doesn't look too agressive, but I guess it's a matter of a proper equipment which I don't have. Anyway, is it a proof of my monitor using PWM or should I check it with some better camera before jumping to such conclusion ?
EDIT: Yes, it must be PWM. When I set brightness to 100%, those lines disappear. That means it doesn't really matter to me as I don't notice it at all.
Ah, I must have misread your post. I thought you meant at the settings you put it at (high brightness/low contrast) the gamma shift was improved over stock levels. You meant just compared to what you originally set it at.
If it was me, and I was that sensitive to PWM, I might suggest playing the return game. Just return/rebuy until you get a PWM free one.
I always wondered about eye strain and flicker -- even FRC flicker. It may not bother people on a short term basis, but if you use your monitor for hours on end, daily... for months and months... it logically could cause additional eyestrain.
Besides some Dells (maybe) what are the other PWM free models out there? I believe the 27" Samsung PLS is PWM free (and also insanely expensive) and Eizo just came out with a 24" model. Is that all of them?
Not in computer monitor panels. TV panels have it sometimes. On the other hand it seems rather common that the panel manufacturer also provides PCB boards. At least in cheaper models.Is PWM part of the panel itself, or part of the monitor's electronics? I assumed it was the latter, but I am just guessing there. Just wondering if the panel version would even matter if the PWM electronics are on an internal board instead, not the panel itself.
I have S2240M, purchased from Amazon. I have been using a 4:3 HP LP2065 IPS monitor for long time now. For every Dell wide-screen that I tried over the years, I have been able perceive uniformity issues. The viewing angle tests at Lagom LCD Test website are the best example for seeing this at its greatest degree (specifically the first image).
On my S2240M, the left side of the screen is cooler moving toward the center it is neutral and has a slightly warmer appearance on the right side. This is noticeable to a lesser extent while web browsing, but on common white backgrounds the left side almost has a feint blue tint while scanning left to right.
I am sure this appearance is affected by viewing angle. When the screen is to my left I and I am viewing at a nearly parallel angle, the entire screen appears cooler, while the opposite is true when viewing it in the same manner from the right.
I am not sure if it is a coincidence or not, but on a completely black screen the IPS glow coming from the left side of the screen is yellowish while from the right it is blueish.
I have been able to limit the intensity of what I am able to perceive by raising the center of screen to my eye level (on a stand) and increasing my normal view distance slightly (~24 inches).
I know the relevance of this is not really applicable to the S2440L due to it being a different panel type, but has anyone else with S2240/S2340 been able to perceive something similar in the quality of their screens? If this is fairly common, I am pretty sure I would be willing to settle with it, because it is such an affordable screen at ~$142.
Thanks! Summarize the answers it gave me to my own inquires:The first good S2340L Review is up, in Russian
http://www.overclockers.ru/lab/5076...bzor_i_testirovanie_monitora_Dell_S2340L.html
- 300hz PWM.
- Again the aggressive overdrive with overshoot that cant be turned off.
- Very good contrast (1300:1).
hi all.
there was a post back a while ago that told of how to check the factory settings for the panel model number. This with the dells.
but my s2440l has a different set of buttons and options, how do i get to the service settings?
I asked once and the reply person just only wrote that yes this is done.
i could not understand this. there are no buttons on the s2440l, just areas to press to bring op condensed options for the settings. so how DO I find the panel number without taking my monitor apart?!
the above explainations to me seem to explain the pwm problems well.
thank you.
freestone
im not familiar with FRC flicker. any demonstration for it?
Any 6 bit panel with FRC (to get it to 8 bit) will have it. It won't be visible to most people. In fact, I expect hardly anyone would even notice it. But it theoretically could lead to eyestrain after hours and hours... and weeks and weeks... of use. Just something I've wondered about.
It won't happen with VA panels, as they are all 8 bit anyway.
I thought FRC flicker is usually only visible with certain grey scale gradients, as in, if you go hunting for it when using gradient tests (lagom or Flat panels) you will find it...but not during real world use.
FRC also works at 3000 hz it seems http://www.youtube.com/watch?v=kZobrwFgWg0
the gamma shift in greys on the s2440L panel i was talking about seems to be present on all Dell S series models even IPS. doesnt seem to be a fault of AMVa technology see the video here describing backlight leakage http://translate.google.co.in/trans...bzor_i_testirovanie_monitora_Dell_S2340L.html
no, the ips panels have ips glow. it's a different issue to va gamma shift.
so this is a polariser issue? combined with the gamma shift of amva?
