pendragon1
Extremely [H]
- Oct 7, 2000
geeeezz...
I was cringing! using the vice method on a 6950x!
geeeezz...
to knock off 10-20C and because no one else had put it on YT yet. he is begging for subs and views, trying anything he can. theres another vid on his channel talking aboot it.But why??
lol
ok then, I guess just the parts after the 10-20c drop... idk... epeen and desperation?!
re-read what I said then man....
I said that the parts after the 10-20c drop applies, epeen, desperation, needing views etc.
if it was soldered the drop wont be as much. I was agreeing with you!
ps: the 10-20c drop is the average people are seeing on de-lidded 6700/7700 etc, which are not soldered.
Ahhlol
AhhI didn't realize that the 6950x was soldered and that the temp drop would be insignificant, so that part is void. everything else I said applies.
see you got itAhh
Careful there
This CPU is soldered (methinks, right?)
People usually get like 5 degrees better Temps by removing the IHS compared to soldered
Removing the IHS
Only thing being problematic about solder could be that the IHS is not very even
I remember having to lap my q6600 because of this
Ahh
K
now that I think aboot it there prob aren't delid tools for 6950x. but holy shit would that be sphincter tightening!
