jenosmaverick
- May 24, 2017
oh you didn't want the one with graphene? I will be ordering mine next week I got unlucky and my card is full
The temperature is not good...(playing Witcher3). GPU is maintained at 60-70 Celsius degrees. But CPU is over 90 celsius degrees in realtemp.
So I have several plans to lower the temperature.
I will come back with detailed temperature data when I get a payday^__^
Yeah, superbuy is a middleman for taobao shopping worldwide, if you want to have an easier time. They order for you, have the package sent to their warehouse, send you pics of the package like above and can help you pick a number of courier companies to ship to your location.
You can order directly off the taobao seller using google translate if they offer worldwide shipping too.
I bought it from Taobaofocus, same principal hope it will arrive soon!
oh you didn't want the one with graphene? I will be ordering mine next week I got unlucky and my card is full![]()
Just recieved pictures from Taobaofocus, for the Cryorig C7 Cu, but this is not copper color?
hmmm
thats wierd
You seem to have ordered a graphene coated c7, which is a service a taobao seller called grey whale sells. The fan is white with white sleeving, so I'm guessing it's the c7 cu coated in graphene, not the regular c7.
The only way to be sure is to scratch some graphene off and see what color the fins are inside, I guess
How much did you pay for it? Regular price is supposed to be 369 RMB.
When did you order?Just recieved pictures from Taobaofocus, for the Cryorig C7 Cu, but this is not copper color?
When did you order?
The hero we don't deserve, but the hero we need.Oh well
I just purchased the pure Cryorig C7 Cu also, im gonna make a comparison for all of the 3 coolers (Normal Cryorig C7, C7 Cu and C7 Cu Graphene) and also with the noctua fan attached.
I just wanted it all black XD
Sonnyspoon
From the posts of other 8700k owners they delided it first then went with noctua and add multiple fans or aio. 8700k just runs pipping hot.
That will not fit in the Dan A4 Case as it is 112mm in height. Are u using this in a different PC Case?Ok if something go’s wrong i buy the be quiet shadow rock tf2. Is very big but i think is cooling very much than the noctua^^.
That case is not an A4 is prob a chinese knock off,
But he dont have the pure copper version of this cooler.
The Dan A4 SFX no side panel editionThat will not fit in the Dan A4 Case as it is 112mm in height. Are u using this in a different PC Case?
Ah yes I dunno if graphene had any effects at all.
Edit: how much did you pay for the c7 cu w/graphene? price is currently inflated prolly due to demand.
Yes with no side panel^^. But for now i have a problem nothing happen when i push the power button.
I change my mother board
Did you think is my power supply or the power button of the cases is out?
It's an issue with the power button, not the psu. You put the power sw cable in the wrong way, flip it around so the power sw text is facing the ram.
No nothing change.
It’s the first time for me or nothing Happen. Maybe the ram is hs. I switch them but nothing.
At this time my brain is out.
A switch like that will work either way, it justs connects / jumps the pins it is plugged onto.It's an issue with the power button, not the psu. You put the power sw cable in the wrong way, flip it around so the power sw text is facing the ram.
I cut the ones that came with using a dremel, you're after 18-20mm length screws.Can someone who has the Asetek 545 and a Noctua A9x14 recommend me some screws that work with the fan and res? Thanks in advance.
Try jumping the motherboard manually with a screw driver. If it still doesn't start then its definitely not a power sw issue.
I doubt it's a psu issue because the leds are on, but you could try testing the psu by connecting a fan to it with molex and jumping the 24pin with a paperclip to see if the fan works.
