option#3 would also eliminate those tabs on back making the case "look" more compact
It's 45mm. Just a heads up though, I got mine on Wed (ordered from ebay) and unless I'm doing something very wrong (or this thing is defective), it's barely as good or even slightly worse than the NH-L9i.
I've re-seated the thing 5 times already because I still can't believe the underwhelming results I'm getting considering it's rated for 130W TDP. You'd figure there'd be reviews by now so I can confirm my results but i can't find anything yet.
And reduce dependence on plastic (the clips), which could be good for longevity I think.
I also vote for panel screws, for the reasons others above me said. And the case is already a bit too tall, more than it needs to be, IMHO. For the life of me, i can't understand why so many mm lost just for the pci riser bend radius, above the mobo. And if you'll use screws, maybe you could cut and shorten the bends (where the clips where attached), to make the mobo installation easier (in case you decide to shave a few mms from the top).
As Silent PC Review keep repeating, it's extremely important with good contact between heatsink and heat spreader, and a slightly convex base surface on the heatsink usually works out best. How's the base on this one? Flat or convex (or perish the thought: concave)?
Also, have you tried the same fan on both (NH-L9i and this one) as a comparison?
It could be the orientation of the vapor chamber. I know my AXP100 is much more effective when mounted horizontally so the heat pipes can function as intended rather than vertically mounted as in my L2. Noctua actually has a warning on their page when vertically mounting their C-style heatsinks to avoid the orientation where pipe bends are at the top .
Seeing as Noctua isn't in the business of selling crap heatsinks, that doesn't surprise me. A vapor chamber doesn't work magic after all.it's barely as good or even slightly worse than the NH-L9i.
Shorting the hight is not possible. 170mm motherboard over and under it 11.5mm free space (for cables and riser ) and 2x1.5mm material thickness.
I know, but what i was trying to say is those millimeters would disappear quickly and maybe become a problem if you would decide to shave a few millimeters from those 11.5mm at the bottom, like i was suggesting in my previous post.The PCI Bracket doesn't have contact with the AC-Outlet. There are some millimeters between it.
The problem is how longer you work with a cad in small dimensions you begin to think that 1mm is like 1 meter.
These low height heatsinks seem to be primarily limited by airflow. A slim fan isn't going to set any records in the first place, it has to push air through very narrow fins and the heatsink is cowering mere millimeters above the CPU/mainboard.
Even if a vapor chamber is slightly more effective at transferring heat from the CPU to the heatsink fins, it doesn't matter if there's lacking ventilation to remove the heat from there.
Self-clinching nuts will add a bit to the cost of Lian Li can do it, the M1 V2 and V3 has them for the side bracket mounting holes.
I can tell you, with those feature requirements, regardless of how you arrange things the smallest it can get is still about 7 liters....sfx power supply and mini lenght video card, 2x slots for 2,5 inch drives, maximum 60mm cooler...
ps : dan ur case looks very nice, but i really wanted it to be smaller
I'm people and I'm not.i never said to be smaller with SAME gpu lengh. people gonna use the mini gpu from now on
so i created an account just to make a reply on this thread... im really wondering why no one wants to create a very tiny case, having sfx power supply and mini lenght video card, 2x slots for 2,5 inch drives, maximum 60mm cooler. Sooner or later companies want to have their products in tiny edition, so a case that has all of this components can be upgraded anytime.
As i see for some project here and also for my project you start with much less liter as the end-result will be.
The reason is in the CAD it looks very easy but you forget you need space for wireing and mounting. If you have the aim to bring the case on market there are also some other reasons that are increasing the size e.g. support for different psu's, gpu's and coolers. Furthermore the manufracture must be abel to build you creation and the price must be low. All these points will increase the size.
I think the main advantage of the A4-SFX is the full length gpu and sfx support. What do you do if the next gpu generation making a big step to manage 4k resolution which result in the situation of higher power consumtion, more heat and a larger layout? In a mini GPU case the new cards wouldn't be fit, because they are too large, but the A4-SFX will have no problems with them.
Wouldn't be so sure about that. When using screws you have to either cut the thread into the aluminium, or use press in threads like Nova does. The first option is cheap, but as aluminium is quite a soft metal, people tend to put too much torque on the screw and ruin the thread very fast. Press in threads are very good in terms of longevity, but will increase the cost and it may be hard to get that done with LianLi as a manufacturer, as they rarely use press ins in their cases from what I remember.
Yes because there are two shields between it and gpu. One plastic and a aluminium shield. A msata ssd can handle 60-70°C but i think we are more in the 30-40°C area in this case.
Hear, hear.I think the main advantage of the A4-SFX is the full length gpu and sfx support. What do you do if the next gpu generation making a big step to manage 4k resolution which result in the situation of higher power consumtion, more heat and a larger layout? In a mini GPU case the new cards wouldn't be fit, because they are too large, but the A4-SFX will have no problems with them.
What ambient temps did you have?I got mine and went ahead and tested it, it can handle 130W but just barely.
80c on a 130w CPU seems very reasonable for such a tiny cooler. As I said before, a vapor chamber isn't magic.
Oh, just under 16c. Or as Canadians call it: midsummer.15.7°C ambient. I'm satisfied with the temps I got, I don't think they actually expected anyone to use this thing on a 130W CPU
