Mad Catz Rich
- Jul 13, 2010
Which email address are you using?
Controlled 5600dpi !
You can crank the resolution all the way up in the cyborg control panel and then adjust cursor speed in the window's "mouse control panel".
( windows>control panel>mouse properties>pointer options> select a pointer speed! )
If any of you find issues when the thumb rest is tightened, try the following:
1. Loosen the bolt
2. Adjust the thumb rest to where you want it
3. Place the mouse on a flat, hard surface
4. Press down very firmly on the middle of the mouse - the section where R.A.T. is printed
5. Tighten the bolt fully whilst pressing down on the mouse
See if that helps.
Sorry if someone already posted this...I didn't bother to read this thread.
The solution for me was to place a plastic shim in between the thumb rest and the metal frame. I cut a piece of clear plastic off of a screw package (the part that hangs on a display rack in the store) but anything thin would work. I placed it where the FCC ID # is between the plastic and the round part of the metal frame that surrounds the thumb pivot. You might have to experiment with different thicknesses of shims but in my case the first time was the charm. Mouse clicks perfect now! I love this mouse but it should have been cheaper considering that the customers are the beta testers. My only question for Mad Catz is...head or gut?]
Man I really want this mouse but these issues that they are having scare the crap out of me and I don't feel comfortable laying down over $50 for something with known issues. Is madcatz putting out a revision soon that fixes the issues once and for all?
Many months ago I wedged a stack of (very small) paper in between the thumb rest and the metal to get rid of the jitteriness. While this stopped the majority of accidental movement on the left click, both the middle click and right click were still affected. I threw the mouse in the closet and haven't looked at it since then. Do you (or did you) have issues with the middle mouse wheel/right clicking? I'd love to be able to use this mouse![]()
I'm not surprised that TeleFragger's cloth mouse pad is not experiencing this because that type of pad will dampen the rocking.
I have a cat, so that really doesnt help. lol
I love my R.A.T. 7 best mouse I have ever owned.
Has anyone had problems installing the mouse software? I've downloaded the most recent software for Windows 7 64-bit. After the installation, I can't open any of the software. I don't have anti-virus software runing and have installed the most recent drivers.
I've had my R.A.T. 9 since mid January, and last week it suddenly started double clicking (on a single click) every 5 mouse clicks or so. I sent off a quick email to the guys at mad catz. After suggesting that I confirm this on another computer (somehow that though escaped me--n00b mistake ino) they will be sending me a new mouse (due to personal circumstances they have not required me to send them my defective mouse first.
I have to say that their Customer Support Staff are spot on. Many Thanks to Angelo for his help with me and my mouse.
Now nothing to do but wait for my new R.A.T to arrive.
guess ill save my old mouse just in case....
It seems to be a claw mouse now matter how much I adjust the palm swell
The above procedure didn't work to resolve my RAT 9 rocking back and forth when left clicking which would cause my cursor to move erratically.
Did anyone bother to test these? Immediately after install I'm like "What the F***!!!"
Using a flashlight I could see that the feet on the left side of the metal frame were not in contact with my mat because the mouse foot on the thumb rest was propping them up. My initial thought was to sand down the mouse foot on the thumb rest which would work but would also prematurely wear out that foot.
http://img571.imageshack.us/img571/1629/img2353bn.jpg
Can you elaborate on this please? I don't quite follow. I see the plastic thing with the FCC ID on it but I can't quite tell what it is doing.
It's lifting the plastic thumb piece. The base of the mouse is the metal frame. The thumb piece, without something wedged between the two, is just slightly taller than the rest of the mouse, making it wobbly.
I gave up on my RAT 7 for that exact reason; no matter what I did, it was wobbly.
I see. I've tried jamming in some items I found around the house that I MacGuyver'd but I can't fit anything between the metal frame and the thumb rest. Any ideas on something I could use or try to get this thing working? The wobbly stuff is driving me crazy.
If you want a replacement for your MX518, get a G500.So, I gather yall would recommend getting the Rat^3 instead of the other models due to the sensor issue? I am kinda looking for a modern replacement for my aging mx518. Suggestions on the Rat^series?
