Anyone have any thoughts on the MMO R.A.T. 7? I was thinking of giving it a whirl but don't want to drop that kind of coin for it then end up hating it.
Don't go Naga, hardware is okay, but software is pisspoor. Razer Synapse is moody software. Sometimes it will crash,s ometimes it will not run, sometimes it works perfectly. It's like Razer created drivers with PMS
Also, for Logitech, you should read their forums, and people begging Logitech to finally make G700 use Logitech Gaming Software and not Setpoint - I tried G700 with SW:TOr and wel, making G700 remember keybinds, was a hard job, so after 1 day of fighting to make it work, I just sent it back, and will stay away from any mouse that is Setpoint based.
I won't have problems with profile changing manually, and since my mouse is never taken away from my computer, I don't see the point of having profiles stored on her. But to each his own.
The more important thing is, how the sensor works, is it improved from regular Rat 7, and all the problems it had, been solved? If yes, then Naga goes to cellar, and I get a new mouse![]()
Hi, I'm in need of help
I have R.A.T. 9 mouse, but it doesn't work.
I would like to ask you something - should the serial number be the same on the usb receiver and the mouse, or different? Could you check how is it with your mouse?
Do you have any idea how to make the mouse work? It is recognized by WIndows and I have installed included software. The light on the mouse and the usb receiver is on. But the mouse doesn't work. I've tried on many computers.
Thanks
My serial numbers are the same for both the mouse and receiver.
