Zombies, have to make sure that sucker was dead. Wait this is not RE 3Um, at 2:06, why? Lol
Everyone getting the same performance like me only you getting awesome fps . Weird. I dont tell you i not believe you. But look here.
4k. V.HIGH. 30fps
1:13:07 even 28 fps
res 4K , V.HIGH.Raytracing off, still drops to 40s.50's fps.
45:45 that misssion
Just considering to rtx 3090, but not sureSo what is your point? At 4K with very high settings it drops to the 40s? It is 4K, other games have that issue as well. Turn down the settings is the key, put shadows to Med, Vegetation to Med maybe High, Objects quality to High or Med -> Presto faster speed, smoother. Turn down more settings if needed to get RT running in Performance, that greatly increases IQ in this game. If you want 4K and V.High, buy a 3090, I don't think the 3080 has enough VRAM for this game with all VHigh settings. I hit the vram wall at 1440p pretty quick with the 5700XT, the Vega FE goes close to 10gb in this game as it is (less than 5gb with low settings) at 1440p. This game on higher settings have 8K textures, very long draw distances (meaning a ton more objects, textures, shaders etc.). I run smooth with the settings I have in previous video. Turning up a few more settings and I get the frame time pauses, hitches etc. => Not Enough Vram is most likely cause.
Game can also be the issue, Drivers etc. I would expect the 3090 would run this game rather well but until tested it could just be a bad optimization or lack of in the game that does not handle the higher settings transitions from one area to the next right. Eventually I will test it on the 1080Ti with 11gb. The Vega FE just does not have the performance level but does seem to do much better smooth wise with the higher settings, big difference is the 16gb of vram.Just considering to rtx 3090, but not sure
Crysis Remastered PC Review: Beautiful Tech, Brutally Limited Performance
I turned on some more of Radeons software as to push the image detail and bumped some settings to med but ..keep the game running smooth as I can. I didn't see those heck up's in game but It may have something to do with finding a way for Relive to start in game and not on desktop .
Crysis Remastered has been updated to version 1.1.0..."We listened to your feedback and are happy to present our first set of bigger changes, additions and fixes to Crysis Remastered."
those changes include the reinstatement of several features from the original game—leaning, a quick-throw key for grenades, and Classic Nanosuit controls...
https://www.reddit.com/r/Crysis/comments/izkpcc/crysis_remastered_pc_update_110/
Wow they removed all that for the initial release. Garbage.
The performance of this screams poorly-optimized. The game does not look good enough to justify bringing a 3080 to its knees.
I think the original game is the one that is poorly optimized making any attempts at a remaster suffer because of it...there are some nice improvements in terms of graphics but there are also some major downgrades as well...
So how do those visuals and performance compare to the original on ultra? If they are both lower, I wouldn't consider that too awesome.Hey guys. Its awesome. I managed to get 90-100fps. Just all settings on the right --> ALL MEDIUM. Raytracing OFF. Rest options above Ray Tracing,like shadows,shaders etc V.HIGH . Thats with 1440P. On 2080 Ti and 9700K.
ps:
Now i readed that update to 1.1 v was in saturday. Maybe that helped too. I just run today game after few days break.
looking goodSo how do those visuals and performance compare to the original on ultra? If they are both lower, I wouldn't consider that too awesome.
Game overall looks awesome, better in many ways from the old version. Still some things like sub surface scattering for facial material I think look better in the original version. I would definitely prefer this version over the previous. Even on lower settings it look better than the best settings of the original in my experience.So how do those visuals and performance compare to the original on ultra? If they are both lower, I wouldn't consider that too awesome.
yupDoes it still only run on 2 threads?
glad youre out but what does any of that have to do with crysis?!I been in the hospital for 2 weeks and have a lot to catch up with .. I am back on my 3700x / RX 5700 flashed and I did buy the Wal - Mart Black Friday Acer ED32DQR - EDO Series 32" FHD 1920 x 1080 VA panel with 1800R curvature gaming display with 165Hz Display Port and 144Hz HDMI with AMD Free Sync Premium for $155 ... Moving from 72Hz to 144Hz with video card that can reach that in a game like World of Tanks 1080p Max HD is Night and Day ... Not one dam issue with it on 20.1.11 driver and a ref XFX RX 5700 Blower
Maybe the drugs haven't quite worn off yet?glad youre out but what does any of that have to do with crysis?!
Crysis Remastered was such a piece-of-shit remastering job that it put him in the hospital.glad youre out but what does any of that have to do with crysis?!
