may i be worthy
[H]ard|DCer of the Month - December 2010
- Aug 17, 2010
Yes - lets get a lot more data in there.
mmmmm, benchmark data...
i would get rid of the duplicates from the same family go with the higher PPD one. so the 6701 on the Q660 i'd take that off and use the 6702. the 6066 on the x4 630 i'd take that off and use the 6067 thats there instead.
Yeah I like those too, for some reason only my Athlon seems to get them and my C2Q systems have been pumping 67xx units.
You make a good point with the work unit families and I will average them to bring some more stability to my numbers. I will also make a point to come back and update with new averages after I have more than 2 weeks on my clients.
Maybe a column for number of frames observed would help gauge data validity as well?
Temporary ban for a week due to a alleged "personal attack" situation. Whatever.jebo_4jc banned?
What happened? I am in shock...
Added and updated some more information from my tweaked SR-2 Rig, numbers are looking good!![]()
Looks like you shot up 24,000 ppd by going from dual to triple channel - great stuff.
What MCH strap are you on?
@Chilly
6900 0:11:34 156,557
2686 0:11:37 155,554
Are these using the benchmark?
I think it was in the graphics forum or some other forum like it that is constantly filled with too much troll testosterone.![]()
added a plethora of info on a 1090T and Q9450......i wish my 1090T would pick up a 2633 unit here or there, unit is the best one i have for my Q9450 (just about 7.7k ppd on average)
need more phenom II x4 numbers damnit!only 2 of us running them, thats sad.
Its probably because they are such a PITA to clock lol. I have oc'ed two AM3 quads and they were so finicky it turned me off from them until at least Bulldozer.
Honestly its likely just the population of folders that are more likely to frequent the forums tend to have hardcore hardware, my quads are pretty pedestrian.
As have I, in fact I used to fold on a 2600m at 2.6ghz back in the day. Your argument is close though.... the Intel chips made me lazy with how easy they are to clock.but then again i guess I'm the exception since I've been overclocking AMD processors since the socket A day's.
1090T cant run the 2633 WU's. they are quad core only.
yeah i quit using prime95 too. anytime it passes, F@H fails. so i started using intel burn test which is just a modified GUI for linX stress testing. but so far if i pass that i have absolutely no problems with F@H. plus its a hell of a lot faster. usually just run 10 passes and im good.
yeah the 6701/2's are picky as shit. but i dont bother with ram timing/speed on standard SMP. makes little to no difference. maybe 1 second in the TPF. where as bigadv it makes a HUGE difference. wouldnt surprise me with the NB voltage. seems they use the absolute minimum stable voltage for the NB stock. wish i could overclock my damn NB though. damn asus motherboardim stuck at 1.6Ghz on the NB.
It should oc automatically with your bus clock unless the motherboard is dropping the multiplier on its own. The worst case I have heard is mobos that tie the HT/NB multiplier together.
I have my NB at 2300mhz on stock volts with 9-9-9-34 timings but need to increase the voltage to tighten them up. The Athlon II nb is pretty bad, so I would think even your first spin Phenom 2 should match that.
