For an Intel setup, the Sunbeam uses pushpins to connect to the mobo but uses an AMD style metal clip to connect the HSF to the CPU:
http://www.ap0calypse.com/reviews/sunbeam/core/core_15.JPG
Kind of odd.
Sounds like you'd go with the HDT-S1283?
Kind of odd.
Is that with tax included?Called Microcenter to see if they had the Thermalright LGA775 Bolt-Thru-Kit. Turns out they have ONE left of the XIGMATEK ACK-I7751.
XIGMATEK ACK-I7751 + XIGMATEK HDT-S1283 = $45.23
Isn't the HDT-S1283 $30 at MC?
So $10 for the ACK-I7751? not bad. Looks fine to me.
I've only used provantage once, and they were fine... no problems at all. They get recommended a lot here for PSU and case prices, but haven't heard anything bad about them other than your earlier post (which I didn't fully understand).
I 'spose I need to read the "notes" on how to overclock if I want help, eh? Or is anyone here up to that?
A bit old and a little outdated but most of it is still relevant to current Gigabyte motherboards:
http://hardforum.com/showthread.php?t=1169366
And look through this thread for more specific settings for that UD3R mobo:
http://hardforum.com/showthread.php?t=1352805
And finally, post pics of the PC if you can!
That's just pretty much how you do it. The order you install the parts in is up to you. There's no specific method, really.In the past I've had a tendency to just put all the hardware together and go. Anyone have a better suggestion for a process?
By the way. Has anyone seen the HDT-S1283 first hand? This thing is BIG.Even with the Crossbow is this still an issue. That thing is going to be suspended horizontally.
I've got one, and although it's big, it's still manageable. Don't worry about a thing.
I don't bother with all of that messing around. I just put it together, and it generally works. There's no point in wasting time testing each individual component unless you actually have a problem.I know some put in RAM then boot up, then add video card and so on. Have never bothered myself but equipment changes over time and I was curious.
The Crossbow basically just attaches the cooler more securely to the board. It does help, although the push-pins do work fine by themselves.Cool. I took it out of the box and was really surprised. Was wondering if the crossbow helped much since it's not very big
I don't use the Crossbow so I can't say for certain. However, you should probably just screw them in as far as they will go. That's the way it's been with all the bolt-through heatsinks I've dealt with. Also, remember to alternate between opposite corners to balance out the tension properly.In your reply about the Xigmatek. When you attach it to the Crossbow how do you know how much to tighten it down. The springs are a nice for tension but....
Sometimes Gigabyte mobo's designate the E8400 a 8.5x multiplier instead of 9x. Something to look out for.
I've had absolutely no problems with mine, although I don't exactly move it around a lot. I doubt you'll have any problems with too much tension though. The bolt-through kits are designed to apply the proper amount.Hmm..makes me a little concerned. You just used the push through pins with this HDT-S1283? Seemed it was a concern of the mb taking stress and causing damage. Come Monday I'll see if the manual makes any recommendations. I would think it would be easy to have to much tension and cause problems.
Well, if that is indeed the case, it'll just boot at a lower frequency, which will be easy to spot when the motherboard reports the CPU speed during POST. All you'd have to do is change the multiplier in the BIOS, which is trivial.Apparently if it won't boot or if you see the wrong native Ghz speed at post you'll find this out? Then adjust in BIOS.
One side of the fan has the struts that connect the motor to the casing. That side should be pointing into the fins.Doh...which way to face the fan on the S1283? I know which way I want it to blow but not sure which side should attached to the S1283.
How big is the S1283 in the CM590? Half the width?
I'm also interested in how quiet it runs, if you don't mind reporting after you're done.
WTF...BSOD so fast I cannot read it.
Next time when you boot, do this:
http://vistasupport.mvps.org/disable_automatic_restart_to_read_blue_screen_messages.htm
Keep it at IDE for now. And just for the hell of it:
[Testing the RAM]
Download Memtest+ v2.10 or whatever the latest version is, unzip it, burn the ISO file to a CD, and then boot from it, just like you would do with the XP install CD. Let Memtest+ run for at least three hours on each stick of RAM separately as well as test the RAM together. Go for a full 24 hours if you want to be completely sure that the RAM is not a problem. If you start seeing errors, than your RAM is defective or you have incorrect settings for the RAM.
[Testing the Hard drive]
Download the CD image of Hitachi Drive Fitness Test, burn the ISO file to a CD, and then boot from it, just like you would do with the XP/Vista install CD. Test the hard drive and see if any problems are found. DFT will run on most manufacturers' hard drives. Alternatively, you can use Seagate's SeaTools for DOS to test a Seagate or Maxtor drive. For a Western Digital drive, you could use Data Lifeguard Tools for DOS to test a Western Digital drive.
Nice: running Memtest +86 v2.11 and getting lots of errors right away running at 1066! Bad RAM or bad setting somewhere? Hey..it may be something I'm doing I'm not sure.
I drop to 800 and don't see errors yet.
Your thread is so long, what RAM do you have again? I agree with Danny, it might just be your voltage setting.
