sanitarium16
- Dec 5, 2007
To wait or to upgrade to x299?
Atleast with x299 you'll have more CPU upgrades before having to need a new Mobo
The 7820x is ony about $180ish difference over the slower 8700k system with it's slower dual channel memory.
In fact some of the best motherboards you can get for the x299 are only $250 - $280. The reviews on these boards are way more favorable than the expensive x299 boards. So motherboard wise, you're not going to have to spend any more on a great x299 board.
So it really comes down to ...if you have the extra $200 for x299/7820x
Don't listen to people that suggest you wait for the 8700k. Why? Money is their motivating factor or lack there of ..... It's certianly not performance or they would be telling you to get the 7820x.
If you're one of these deep IT/coder cpu feature nerds, then sure their could be some obscure feature that might be missing between the two but for 99.9% of everyone out there this is not going to effect anyone.
The only downside to x299 is the slight additional cost. Which can be mitagated by not fucking off your extra money for a week or two. Fastfood? Eat at home? Girlfriend? Do something free. Etc. Easy to recoup/save $200 if your motivated, patient, etc.
7820x provides 8 cores / 16 threads, Quad channel memory. It's extremely fast at gaming and productivity. Resellability on a 7820x system would be higher than that of a 8700k
If you have a Microcenter near you the 7820x is only $549. That doesn't count the $30 Motherboard/CPU combo they give you as well.
If you hate tax and can wait 3 or 4 days I've heard that Newegg matches Microcenter now. Not sure if this is true.
I just built a 7820x with 16gb of 4400mhz memory, will be adding an additional 16gb soonish. 1tb EVO 960 NVMe SSD. Insane performance ......
It looks like many folks are getting a pretty good overclock out of the 7820- 4.3Ghz at least, right?
4.3 is the default all core turbo 2.0, 4.5 would be turbo 3.0 for 2 strongest cores although I see all my cores jump to that speed, not sure hwinfo is reporting everything correct though.
They seem to overclock pretty easily, haven't tried on mine yet, but seen people getting 4.6 on all cores pretty easily.
So I am going to return my 8700k and get a 7820x instead. It just makes more sense to me as I am 90% gamer but that 10% I want to be a power user. I literally want to be a power user if you know what I mean.
If you play at anything higher than 2560x1440, the 7820x is the way to go. Do you play at 3440x1440? The 8700k is awesome, but it is mainstream. It's platform was simply not designed to be as robust as x299. I can upgrade to the fastest desktop CPU ever made by just swapping chips. That is kind of a nice thought.So I am going to return my 8700k and get a 7820x instead. It just makes more sense to me as I am 90% gamer but that 10% I want to be a power user. I literally want to be a power user if you know what I mean.
As nice as your 8700k overclocks I would sell it, especially with what people are paying for them on ebay.
