- Sep 6, 2006
About 270 on some 4th of Julyish sale.what that run you?
The carbon was on my list, but I do not have a dedicated space and didn't quite feel like lugging it on and off the shelf.
ahhh gotcha...About 270 on some 4th of Julyish sale.
Anyone have a Printables.com account? Follow me, and I'll give you a follow! https://www.printables.com/@Jammy_1827378/models
I've been gathering all the models I modified and reuploaded them as remixes and uploaded pictures of my makes. I have 2 original uploads that I made. Nothing too fancy, but I'm working on point farming for a free spool of Prusa Filament.
I made this. Can you guess what it is?
whoops.. was running out the door and yes a link would be better!!! HAH...A link would be helpful... I used google lens for you. https://www.printables.com/@JeffreyRiggs_1546108/collections Thanks for the follow!
Currently just Dwalt hand trigger c-clamps.but I don't know how much pressure you're applying against that leather..
Yup - used reg PLA.PETG would be the worst material for leather stamping cause its supposed to be soft and flexible.
There's a 50/50 the model may be in my buddy's food truck so I wanted something with a slightly higher glass temp than PLA. Plus it's what I had on hand for higher temp work. I am steering clear of ABS if for nothing more than fumes and preconceived notions of being a PITA to print with.How come you can't use PLA for that painted model? Exposure to heat? If so... then it's time to move onto ABS.
Seems like an easy extension is add a recessed area for a magnet so you can attach your refreshment to many surfaces and angles."Fromunda-Desk Can holder"
The original creality heater block is total trash. I have always used the Triangle Labs CHCB-OT heater block in my Sprite Extruder for my Ender 3 V2, Ender 3 S1, Ender 3 S1 Pro. The one for the Ender 3's will also work for the CR10-SE. But... there are a couple of other different models of the CHCB-OT heater block depending on which printer model you have. But the stock Creality heater blocks are pretty unreliable.... and this was waiting for me under the fan shroud.
Fair enough. My old Ender3Pro I kept stock on the hot end and didn't have an issue for the 5+ years of use outside of once and a while changing a worn nozzle out. Though I wasn't pushing that to any crazy speeds or filament.But the stock Creality heater blocks are pretty unreliable.
Nicely done! Whatcha do for settings - 4 walls and 20% infill?using PETG
