Cablespider
- Jan 21, 2006
Damn it! Anyone else seeing long load times in BC2? I don't usually complain but come on!
People on Rage3D are saying the same thing. LOL ATI.
Still nothing about fixing the mouse corruption issue. I have in some games such as starcraft II and heroes of newerth. I really hate the bug too. The only way to fix it is to restart the computer or go into sleep and back out.
if you check @CatalystMaker's twitter tweeted about it:
RT @XandeAssis_: @CatalystMaker the mouse issue and 2D issue still remains under Win7 64... Can u help me? ME - update your mobo BIOS
Confirmed. Updating my bios FIXED this issue for me!
What a load of shit. 2d sluggishness and mouse cursor corruption problems still exist in 10.5. Updating bios does nothing.
What new bios? It looks like the previous post said motherboard bios upgrade. My motherboard latest update was in 2008.New BIOS fixed the mouse issues for me.
Does this fix the issue with eyefinity and the monitor w/ active adapter going to sleep? The one that was introduced in 10.4a and subsequent drivers, but not 10.3b and the ones prior? Guess I'll install it and see for myself.
No, this does not fix that issue. My DisplayPort adapter monitor is still going to sleep.
You can fix the 2d multiple monitor clocks by modifying a config file. So no - it has nothing to do with Powerplay.
The cards still idle at 400/1000 but if you enable Overdrive they idle at 157/1000 and if you overclock there is not flickering anymore (because the clocks don't go down to 157/300).
Rebooted into VGA mode again. Used the command line uninstaller, ran driver sweeper, then Rebooted. Ran the install again and all appears to be working fine.
I've found that the memory clocks are what generates the most heat at idle, though. That and voltage. So it's not going to be a big difference.Maybe because those clocks could be lower? The core clock doesn't need to be 400, 157 is fine. It's the memory clock that matters.
Not everyone has huge ass cases (higher clocks = more heat = more noise).
Why is everyone bitching about their card idling at 400/1200 with dual/triple monitors? They did this because the cards at 157/300 can't power more than one display without flickering.
It seems to be a hit or miss thing :\ Are you overclocking with Overdrive?mine idles at 175/300. i have 3 screens w/ no flickering. with my fan profile i keep my card down at 37C at idle
btw is this even worth downloading? everyone seems to be complaining about it
So...
Did anyone actually find a single benefit to 10.5? Looks like just problem after problem. GO AMD!
*sigh*
Does this mean my 4850 will not GSOD whenever I enable Overdrive and running multiple monitors?
If the feature was not supported before, why would it even let you enable Overdrive with multiple monitors hooked up in the first place?
Works the same for me as 10.5 betas from April did. 10.4a had multimonitor flickering for me that the 10.5 base fixed. 10.5 > 10.4 for me, although I am an Eyefinity/CFX user..So...
*sigh*
Guess I'll hold off for the inevitable 10.5 hotfix....![]()
