Checkemdown
- Nov 2, 2009
ATI Overdrive enhancement – full support for multiple display
configurations
ATI Overdrive has been enhanced – delivering full support for over-clocking
functionality on supported ATI Radeon™ HD graphics accelerators connected to
multiple display configurations
new feature
Just a heads-up for everyone... They snuck a "Communication Opt-In" with the installer. If you don't want it installed, hit "Custom" during setup.
This was in the 10.4 set as well. Update drivers much?![]()
https://a248.e.akamai.net/f/674/9206/0/www2.ati.com/drivers/10-5_ATICatalyst_AppProfiles.exe ("use amd.com as referrer") or http://www.megaupload.com/?d=K9NFWBUDcrossfire profile link is dead
2D clock issue with multiple monitors still not fixed... what a surprise.
Under Multi-GPU configuration with Crossfire enabled, setting both "Shaders
Quality" and "Post-Processing Quality" to "Enthusiast" may cause the frame rate to
drop in "Crysis Warhead" DirectX 9 game
This won't ever be fixed unless they disable powerplay and have you sitting at 1200/4800 GDDR5. It's a GDDR5 issue, and that is why Nvidia cards don't downclock period with multiple monitors.
ATI Overdrive enhancement full support for multiple display configurations. ATI Overdrive has been enhanced Delivering full support for over-clocking functionality on supported ATI Radeon HD graphics accelerators connected to multiple display configurations.
So, I'm assuming that high bit-rate audio will never be fixed either since it's supposedly a PowerPlay issue also?
Nice, but has it fixed stuttering and performance in tri-fire and quad-fire configs? Just wondering. I just sold my 5970. Hope that was the right move. I'll be working on my waterclocking system next for both better performance and LESS NOISE. ^_^
Useless drivers, no performance improvements at all!
So many games out right now that needs performance fixes. What are they doing?!
Out of curiousity, what exactly is there besides Metro2033??Useless drivers, no performance improvements at all!
I installed these drivers, and now the max resolution is 1400 X 1050. When my monitor supports 1680 X 1050. Last month's drivers did the same thing, so I can't install anything new :-(
Yes.P.S.: If I overclock, is it normal for the memory clocks to be at the overclocked speeds even during idle? Say 1100MHz all the time.
Yes.
Wait, so they DID fix the bug? Getting conflicting reports here...And I can finally overclock without the card doing 157/300 and getting flickering.
+ 1 Billion, I skipped 10.4 but will definitely be installing for this one.
I've been waiting for this fix for YEARS.
Haha
No kidding, I always thought it was the core drop that caused flickering, not the memory. Awesome, will install when I get home from work, thanks!The cards still idle at 400/1000 but if you enable Overdrive they idle at 157/1000 and if you overclock there is not flickering anymore (because the clocks don't go down to 157/300).
