Case Fan Poll
How many fans do you have in your case?
  • Total voters
    151
10 Fans Total
1x 120mm (PSU-Exhaust)
1x 72mm (ATI Silencer-Exhaust)
2x 80mm (Case-Rear-Exhaust)
1x 80mm (Case-Blowhole-Exhaust)
2x 80mm (Case-Sidepanel-Intake)
2x 120mm (Case-Front-Intake)
1x 92mm (CPU-Freezer 64 Pro)
2 x 120 mm hard drive intake
1 x 120 mm power supply intake
1 x 80 mm power supply
2 x 120 in/out (cpu)
1 x 120 on Ninja
1x 120mm exhaust
1x 120mm intake
1x CPU stock 80mm
1x GPU stock don't even know the size
2x 80mm PSU
6 total
it will be
1x 120 intake
1x 120 exaust
1x 80 on ram
1x 92 on cpu
1x 120 on psu
5
2 Rigs (both really similar) and 4 fans in each.
2 X-QPacks 4 fans each
1x120 Out
1x120 PSU
1x92 CPU
Video Card
HTPC
1 Fan in PSU (140mm)
Server 2 Fans
1 PSU
1 processor
SN25P
Factory 4 fans
4 total:
P180 with:
2 120mm exhaust
1 120mm lower chamber fan
1 120mm PSU fan (S12)
By this time next week my WC gear will be in and one exhaust fan will be turned into an intake fan on the rad.
2x120 intake
1x120 exhaust
1x120 in my psu
92 mm Zalman cpu cooler
80 mm Zalman vga cooler
All runnin through a Zalman fan controller. The 2 front intakes are on the 5v-off-12v switches. Everything else is on the rhoebus knobs.
2 x 120MM case fans
1 x 92mm on zalman 7000Cu
2 x 80mm power supply fans
1 x 70mm (I think) stock x800 xl cooler fan
All are temperature controlled. Powersupply takes care of its own, 120s + 92 off motherboard headers and controlled by Speedfan, ATi fan controlled by ATiTool
3 total--silence is golden
1x120mm @5V on the side panel blowing on all those glorious passive heatsinks (CPU, NB, GPU)
1x80mm @7V exhaust, ducted to the CPU
1x80mm PSU fan
12 without psu
14 with psu.
dual radiators with push/pull config adds up...
3 120mm case fans
1 120mm haf fan
1 80mm blowhole
1 crossflow
1 in PSU
7 total in my Stacker
2 120mm case
1 120mm cpu
1 slot blower
2 120mm psu fans
6 total in my LianLi
Lets See
1 80 front intake
2 80 side intakes
1 92 rear exhaust
1 92 top exhaust
1 PSU
1 CPU fan
2 GPU fans
1 really noisy chipset fan*edit*
10 total no wonder my case is so damn loud
thats about it
2 x 120 as blowholes
2 x 120 air in case (1 frt and 1 rear)
3 x 120 air in to HDD area (2 x 120 vents on opposite side to exh air)
2 x 80 air in to PSU area
1 x 120 in PSU
1 x 92 cpu fan
in V2000B case all on temp controlled controller so they only run as needed, all are Cooler Master LED fans which are real quiet and are very quiet with all running full speed
Total 11 fans
4x80 case fans
2x80 psu fans
1x80 cpu fan
1x something slot blower
1x vga cooler
9 total.
Case hides in my desk, so I only hear around 25db of noise...
PSU 120mm
Exhaust 120mm
Side Intake 250mm
Front Intake 140mm
CPU 120mm
VGA Cooler 80mm
I guess that's 6. :D
Which is funny because that renders all 9 of your fans useless.
No airflow = no need for fans
There is airflow in my desk; there is a large hole in the back that gets plenty of airflow because my desk is next to a door.
Don't trash my setup if you have never seen it; that is ignorant.
So if your PC blows all the hot air out the back, where does it get the new/colder air from? I'm just saying if you have no air intake you don't need so many fans. All you'll need is exhaust.
And I'm still gonna "trash" your system 'cause my dad can beat up your dad. :rolleyes:
It is a temporary setup anyways; you are partly right. The area gets so much airflow though it is irrelevant :D
Oh, and my dad can beat up yours better :p
Does this count video card fans? I've got
1x 120mm front intake
1x 120mm top intake
1x 120mm exhaust
1x 120mm cpu
1x 120mm psu
1x 80mm video card
So that's... 6. Do you guys think I really need the top intake? I'm still undecided, I don't think it does anything for temps...
1x 120mm top intake
1x 120mm exhaust
1x 120mm cpu
1x 120mm psu
1x 80mm video card
If yer keepin' track of your temps then disconnect the top fan and check your temps again. You'll figure it out right quick. :D
Oh yeah?! Well my mom can beat up your mom's sister's cousin's daughter's best friend! What you gonna do bout dat?!
:D
Oh btw... I'm just jealous 'cause you actually have a desk to put your PC in. lol
