Parja
- Oct 4, 2002
I want to know if someone can clear up a question about all of the usernames/passwords that are needed to get started.
When I install the client (maybe it is not needed if I am installing a miner?) I need to set up an rpcuser & pass.
When I join a pool, I will set up another username + pass.
The pool wants me to have a worker username + pass
Finally, if I have a Mt Gox acct, I assume I will need another username + pass.
Of these 4, do any of the usernames/passwords need to match up for the programs to run or me to get credited correctly, or should they all be unique? Does the wallet have a password involved, or is it the pool's account info the password that is commonly mentioned that needs to have a strong password? Sorry for all of the questions, just cannot find a clear distinction on the bitcoin forums.
Yeah, lots of accounts to be created at lots of places.
As far as the bitcoin client itself, as long as you're joining a pool, you don't need to create a username and password.
But yes, for any pool requiring registration, you'll have to create account credentials for that pool then likely create credentials for each worker (you then use the worker credentials in your mining program to connect each worker to the pool).
And for Mt. Gox, or whichever exchange you use, you'll have to create credentials.
Your wallet doesn't really have a password. Its security is based on matching up of a pair of hash keys (one is the public key "address" you use for sending and receiving coins and the other is stored in your wallet.dat file). Lose your wallet.dat file and your coins are gone...proper fucked, Tommy.
So to maintain security and safety of your wallet, you'll want to make regular secure backups of your wallet.dat file and store them somewhere safe and secure (I create encrypted 7z files and e-mail them to myself on my Gmail account).
