I know this goes against everything you've been taught but have you tried to partially cover up some of the vents on the case to get the temps up a little more? It might help to get the video card temp up to 88C-90C, which shouldn't hurt it? The ambient temp in the case will rise as well. That may just help enough...
That's just stupid. For given settings, the amount of heat the GPU puts out is the same regardless of what temperature it's running at.
LOL...what? Do you even understand thermodynamics!
There's a difference pumping out 30CFM's at 70 C vs. 85 C or whatever, without upping the airflow. And what do you mean "amount of heat the GPU puts out is the same regardless of what temperature it's running at". That is just stupid right there!![]()
A large temperature swing makes a pretty significant difference in power draw. One of my mining rigs is in my unheated garage. In the summer it was drawing about 700W on 45C air and now with 0C air it has dropped to 615W.
I have a 6970 and the most I've seen it mine was at a rate of 393.6 Mhash/s (-v -w128). I've grown tired of deepbit and am trying out another pool (Simplecoin.us). I'll see if there's any difference in returns.
More to the point of this post, even when mining 24/7 and the GPU is at 78 C, it is not heating the apartment at all. If it was in the bedroom then things would be different, besides actually feeling the heat, the resulting insomnia from hearing the fan spinning at over 5000 RPM wouldn't be so great.
The apartment is like 754 sq ft. The bedroom I'm estimating is 225 sq ft, maybe less. That leaves the mining machine to heat 529 sq ft. Apparently, its too much and I'm sitting here freezing my ass off as I type this. I may soon shut it off entirely since I don't know how long I can last being uncomfortable in my own living space. But all that previous talk about it being a space heater, maybe for dual or tri-cards it might actually work, but this is my own experience. There is just not enough heat produced to make any noticeable difference in the ambient temperature of the apartment. So that space heater idea is now down the toilet. I'm going to try turning the tower around so it's facing the open part of the room instead of the wall, but I'm nearly convinced it's a wasted effort.
Anyone else freezing their assess off as they rely solely on their mining machine for a heating alternative?
Yep, any combination of things. It could even be the effect of the temperature on the kill-a-watt. There is a relation between temperature and power consumption with silicon though.Couldn't that also be caused buy an increase in the psus efficiency due to colder temps?
Yeah, I only brought up the "mining rig as a space heater" topic since there was all this buzz during the summer that the net loss due to power usage wouldn't be so disproportionate because you'd need to be heating your place anyway. As I've found first hand, it won't work in any room larger than a bedroom at least with my card. I have a Corsair 600T case, so there's no shortage of airflow. The baseboard heaters which I have draw between 1,000 - 1,500 W depending on the lengths, and there are several. They will obviously heat the room up fairly quickly, but I'm not clear on how often they'll need to be used in order to maintain a comfortable ambient temperature. The fact that the mining rig makes no perceivable difference in the heat of the room has basically talked me into abandoning the operation. It's not profitable. It's drawing power from the wall but it isn't doing anything more than raising my electric bill. Too bad, it definitely made the room quite warmer in the summer if it was left on during the day, but at this point, it's just full of hot air.
$5 you say? May be worth firing the farm back up, Sold most of it off already tho.
Quite well, actually. I've got a BS in Mechanical Engineering. About a quarter of my major level curriculum was Thermodynamics and Heat Transfer.
Kardon or anybody else who has downsized, you got any x16-x16 patch cables laying around you need to get rid of? I'm getting a spotswood case and need 2 or 3.
lol, looks like we're back in business
I blew a fuse
Yeah, I feel you. I can't run my 8x5830s and 2x6950s at the same time on the same breaker![]()
So how many of you are in the red because of the bust? Seems like it is coming back. Currently at $6.21.
good play, how many coins are you upto now?
