Contrast (ANSI) 288:1
They must have a strange way of measuring. Because ANSI contrast is the static value and that is the lowest number I have ever seen.
Full On/Full Off numbers are OK, but that allows dynamic contrast to kick in.
Colours seem quite a lot better than what they measured on the VW2420H.
Contrast measurement looks very good too.
I have an EW and VW coming direct from BenQ. I'll post quick reviews as soon as I get 'em. I doubt they are sophisticated enough to do local zone LED dimming, so we'll see about the contrast.
I highly doubt they will be 288:1 contrast ratio unless panel blocking kicks in at low brightness, though.
Don't worry about those measurements they are wrong. There was one Asian site which actually properly measure the out-of-box contrast and it was over 3,000:1, respectively they got around 1,000:1 with the Dell U2311H which is also correct.
http://translate.googleusercontent....le.com&usg=ALkJrhisWiYqgFy5jH-vGssQUt6QhHaxQw
Average luminance (cd / m 2) 261
ANSI Contrast 3012.753:1
this is pretty good
i wonder if contrast stays fairly steady with a decrease in brightness? could be a very nice display for watching movies and gaming in the dark, which my zr24w is terrible at - i have to keep some lights on or use some sort of bias lighting because the contrast is so bad
3000:1 contrast at 120 cd/m2 would be pretty amazing, does anyone know how low the black level would have to be for that?
Contrast doesn't vary like that. Your results have serious rounding errors. 0.03 is not precise enough. That could mean anywhere from 0.025 to 0.0349, which translates to 4400:1 to ~3150:1. Measuring at full brightness will give you more accurate results, and looking at the profile data will give you another decimal place.NCX said:0.04cd/m2=3,0001: @ 120cd/m2.
The F2380MX (C-PVA) can go over 4.000:1 if I set the luminance to around 110cd/m2 (black depth=0.03cd/m2) or 3300:1 @ 163cd/m2 (0.05cd/m2) which is a more pleasing result sense most people will find 120cd/m2- too dark.
Besides who want's to read these sorts of numbers, it's far more "commercial/simplistic," to post 0.04cd/m2 or 0.13cd/m2 over 0.0349. In reality it also doesn't matter to 99% of people unless they are debating between 2 displays that both can do 0.04cd/m2 @ 120cd/m2
where to order it?
When measuring such a high (medicore) black value 0.10cd/m2+ BasICColor will display 0.11,0.12, 0.13, ect. When the luminance drops I haven't come across a # like 0.0345cd/m2, is this because it's "inaccurate?" Or is the black value actually 0.0x? Who actually knows?
BENQ BL2400PT (9H.L4RLB.SBE)
so this is PVA and LED?
Why so cheap?
I'm curious where you guys think this will be against the new LED Dell ST2420L?
Rounding errors or not, I'm very much looking forward to your initial impressions.When talking about such deep black levels I still don't think it really matters what the rounding error is considering the F2380MX (330$ Canada only) has no proven competitor (Ezio EV2333 costs 700$ here).
Ordered the EV (256$ CAN @ NClX), should be here within the next 3 days. We will soon see if its truly 3,000:1 and has decent motion performance.
Hi,If you have specific questions or test you would like me to run, just tell me. I don't have any digital camera, so probably it will have to be enough to describe it in words.
To NCX ..... have you ever used an IPS screen with a hard AG coating? How does the monitor compare? Glossy/Matte? Thanks for the info.
