BenQ new VW2420/EW2420 VA panel with LED backlight.
Discussion in 'Displays' started by GTOViper, Jun 30, 2010.
  1. EagleOne
    EagleOne Gawd
    690
    Sep 13, 2005
  2. drleospaceman
    drleospaceman Gawd
    518
    Feb 12, 2009
    Can you disable the blue LED on the 2333t? It seems awfully big and bright.
  3. ManCannon
    ManCannon 2[H]4U
    2,451
    Aug 9, 2004
    I'm seriously considering buying two more of these for Eyefinity. Just worried about the quality control. I suppose it's not that big a deal if they're going to be in my peripheral vision but I know if there was a glaring issue with either one it'd bug the hell out of me.
  4. NCX
    NCX [H]ardness Supreme
    6,224
    Jan 9, 2010
    Just get them from somewhere that offers a decent warrantty service if you plan on having them for a while
  5. steal
    steal 2[H]4U
    2,149
    Apr 12, 2002
  6. joeshmoe
    joeshmoe Limp Gawd
    468
    Aug 18, 2009
    Actually they will also include new features such as Picture in Picture, Picture by Picture.
    The original EW2420 has speakers (1.5w x 2), the new ones will have 2w.
    They also support a new metallic body design which looks pretty sweet.
  7. Soyabeaner
    Soyabeaner n00b
    1
    Oct 29, 2010
    Hello. Long-time lurker, first time poster here. I just received the EW2420 today with no noticeable defects except for the left edge light leakage, but it's not that annoying enough :). I guess I got lucky considering this was one of the earlier units (manufactured on 10/10/10). Quite an upgrade from my Acer X223W. After playing around for hours and reading settings from various sources, I've settled on Kikou's setup. Thanks! Only differences are I set my Brightness to 50 (I've always liked even numbers since back in the CRT days for some reason :D) and Sharpness to 4.
    There's one thing that's unsettling:
    http://www.lagom.nl/lcd-test/white.php --> The RGB colours have the most control in making the last row of blocks visible, but the last 2 remain invisible.
    http://www.lagom.nl/lcd-test/black.php --> Gamma changed from 2.2 to anything lower will make the blocks more visible, but the first row would still remain invisible. Also, although it's true that Gamma changed to 2.0 will eliminate banding, the colours in generate don't look natural to me.
    I'd be curious if someone has actually fully passed those two tests.
  8. tQz1
    tQz1 [H]Lite
    85
    Jul 31, 2008
    Am I the first EW2430 owner here?
    Question: does the EW2420 also have 3 AMA settings (off, high and premium)? What's the difference between high and premium?
  9. joeshmoe
    joeshmoe Limp Gawd
    468
    Aug 18, 2009
    The EW2420 only has "on" & "off" settings for AMA. I have no idea whats the difference on the EW2430 for High and premium?
  10. pitbull46
    pitbull46 Limp Gawd
    210
    Feb 8, 2007
    I think this thread should be updated!!
  11. pitbull46
    pitbull46 Limp Gawd
    210
    Feb 8, 2007
  12. joeshmoe
    joeshmoe Limp Gawd
    468
    Aug 18, 2009
    I think there isn't any new VA panel monitor from BenQ recently? They have the new XL2420T which is pretty cool though!
    Is there something you want to update with pitbull haha
  13. CRT
    CRT n00b
    15
    Dec 24, 2011
    Does the BL2400PT = EW2430 ? Or are there differences ?
    I understand that both are better than the older EW2420, but how do they compare in terms of image quality ?
  14. CRT
    CRT n00b
    15
    Dec 24, 2011
    Does anybody know about this ?
    I think I read they have the same panel but different settings (something like EW2430 ≥ BL2400PT > EW2420), mainly improvements about dark (near black) details and colors, but I'd like to hear from someone who knows for sure.
  15. zod96
    zod96 Suspected BAD TRADER
    2,709
    Feb 23, 2008
  16. XoR
    XoR Gawd
    834
    Jul 25, 2011
    if it have the same panel as every other LEV-VA BenQ then just forget about it :eek:
