Is this the same Samsung: http://www.samsung.com/hk_en/consum...DS/XK-features?subsubtype=sa650-and-sa850-led ?
Guys, I feel for you. There are some things that you mention (such as noticing ghosting) that could be sujective, so my input there doesn't help much. There are other things that I could measure that are more objective, and my 27" just isn't doing those things. I wish that I could get my hands on a 24" version to witness this myself.
As for running tests, I'll run any that I can, so just tell me what you need. A photo comparison to the ACD might not be happening because my wife and I don't want to deal with the hassle of messing with one of our desktops on a work day (I work Fri-Tue) with 2 kids to deal with. So, I'll just give the best impressions that I can in that regard.
I had previously gone through 4 of the best-reviewed non-120hz TN panels, and this by far beats those in every area except response time (which is close enough for me). There is no way they are using the same panel in those 24" models as the 27" model, based on what we've seen in this thread.
Edit: The only thing that I can think of is that the non-HM versions (what we got in North America) are using lower quality panels. Case in point, usually when a monitor is offered in both 24" and 27" variants, running the same resolution, the price difference isn't too significant. For Samsung, it's $30-$50. For the 2450 vs. 2750HM, it's $219 to $399 in BenQ's MSRP. That's more than just 3", speakers, and a DAC. There is clearly something going on there.
Take that black grey bar photo and take a picture like I did. That should be enough to compare our findings.
Hey Medion,
Can you run that same ghosting test from Prad.de and take a picture with high shutter speed? The best I could manage was iso 1600 1/160 shutter, otherwise its gets too dark. Thanks in advance!
This one: http://www.prad.de/new/monitore/testsoftware/schlieren2.html
Why or why has the industry gone down in quality so that nothing new compares to it. This NEC monitor is a 7 year old design. Devolution in the monitor industry? TVs seem to be better than they were, but monitors are going down????
just don't be ridiculousWhy or why has the industry gone down in quality so that nothing new compares to it.
just don't be ridiculous![]()
This video makes it look worse than it really is. Thanks to it being a video with background lighting, it won't ghost the same on your monitor as it does when you're actually using the flash page. Still, I'll get camera shots later if the wife is willing, and compare it at off/high/premium.
That is close to what I saw on the GW2450. Probably the 16ms to 25ms range. So with its AMA on,it is like the average TN and IPS panels in native mode with no over-ride on them.
Anything in the 1080 resolution that is comparable? I do not mind spending $800 to $900 if there is but I cannot find one.
What is the best 1080 IPS now? The Dell U2312HM? That is probably a good monitor but not comparable.
Maybe the ST2220T would be close enough in comparison to the 20" NEC? 21.5" glossy, IPS, touchscreen. Negatives are no height adjustable stand and the screen is on the small side. Also not sure if response times would be so great for gaming.
If you want glossy and a larger screen, then you either go big, 27", or run into the same problem everyone else has... not much in the glossy/semiglossy category at smaller sizes.
I guess ill cross my fingers that the glossy Dell rumor is true but so far only 27 inch noted.
My concern with 1440 is how long before I would have to get a new video card to keep high settings in games with it. I just got a 680GTX but only a single card and reports are some games can not do high setting at 1440 with it even now.
If money is no object for you (within reason), Eizo is coming out with a new Foris model, FS2333 ... IPS (or more likely PLS, if similar to their earlier model). It therefore may be semiglossy too. It should be good for gaming, but I expect its black levels will be so-so... and it'll be very expensive.
@Bun-Bun
thank for photos. Can you also make the same for new Samsung 650?
also is this new BenQ not semi-glossy?
I had BenQ VW2420H that was pretty much similar to this GW2450 from what I gathered. It was more glossy than semi-glossy C-PVA and I could easily see my reflection on monitor off or blacks when whites were in ~120cd/m2 or lower range. So they made it now matte or 650S is even more glossy?![]()
Is it safe to assume that text is easier to read on the Samsung than the BenQ? Usually the less coating = better text. And those Samsung pics of semiglossy are exactly what I picture semiglossy as being... pretty much the same as the coating on my televisions.
When a manufacturer states a contrast level, or a review site does, do they take into account the entire screen, or just a small part of it? Based on you saying the middle of the BenQ has high contrast, while the remainder of the screen doesn't, it sounds sort of like they just stuck a calibrator in the center, measured contrast there, yet overlooked the fact that the rest of the screen has a much lower contrast.
Memoryexpress for $248.61 (price beat)
return policy is within 7 days with nothing missing from the box.
This shows $220. http://www.memoryexpress.com/Products/MX37361
Different monitor or did it go down in price? Oh wait, I am in USA. I doubt they ship to US or it would be a lot either way.
I just sent my U2412M back due to the monitor smelling like burnt plastic and also the No-Glare coating. So i bought the GW2450 to try it out.
So far i'm not impressed at all by this monitor. The monitor does seem to produce blacks pretty good. Have fiddled around with different color options for hours it seems now.
But it seems to lack very badly in the color reproduction area.
While playing D3 the colors are so washed out and i actually notice banding in Act 1 where there is a lot of fog.
I'm curious to how this monitor is a true 8bit panel when i see more banding on the GW2450 then i did on the U2412m.
Also the viewing angles are extremely horrible. 178/178 that benq advertises seems to be a joke.
The presets on the monitor are horrible. Monitor stand seems cheap flimsy.
Monitor will be going back to Benq as soon as i can find something different to try out.
Also a little worried since there is a 15% restock on returns if it turns out to be a dud.
NCIX, memoryexpress.com also has it for 259.99 this week.
Memoryexpress Canada only?
I hope the GW2750 is better or i don't have a choice and have to buy a TN Panel Monitor because an IPS is out of the question because of the IPS-Glow and aggressive AG-Coating, Dam way did i not buy a replacement CRT back in the good old days.![]()
Holy crap, that 650 looks amazing Bun-bun! but no overdrive scares me a little. I'm looking at my 27" Benq box and the part number appear almost identical to playwares apart from the last letter. Maybe I'll open this puppy up and compare with my TN panel. Also a little worried since there is a 15% restock on returns if it turns out to be a dud.
well I am mostly happy with the Samsung. Maybe I will wait till the GW2750HM drops in price and try it in a few months.
I'm somewhat curious on the Samsung. The S27A650D is the same price as my GW2750HM. The differences I'm seeing seem to be;
GW2750HM (pros)
-built-in speakers and DAC
-HDMI input
-better response
-better native contrast
S27A650D (pros)
-better build quality
-DisplayPort
-semi-gloss coat
-better stand (rotate + height)
For me, I think the BenQ is better. I've found no flaws, and while the light AG coating doesn't bother me (never has), I would have preferred the semi-gloss of my HDTV. But no defects, and after swapping out 4 monitors before it, I've found my stopping point. I couldn't be happier. As a side benefit, despite being limited to 2-channel 24-bit 48khz, the DAC is adequate for a basic desktop. I'm routing my audio through it from my GPU HDMI-out. I've removed any trace of Realtek drivers on my system and disabled via the bios. Slight reduction in system overhead![]()
