Outbreaker
- Mar 22, 2012
I had the IPS235P and no way i would take this over the GW2450GM.
LG.. there's your problem. I'm on my 3rd nexus 4. Terrible quality control.
Still haven't bought them.. ideally want to find someone who has them and can show me the trailing.. specifically if it's lighter trails or darker trailers, a video of some kind would be nice?
Hi I just bought the GW2750HM i can tell right away that i need to calibrate it. Can someone please tell me what software I need to use to calibrate it. I also saw the tftcentral has a ICC profile for it should I use it ? Please anyone with this monitor please share the correct setting I need to use on it.
Thanks
Whats wrong with yours?
maybe read this #237 here page 12
http://hardforum.com/showthread.php?t=1698102&page=12
great! can you please do me a big favour and take a video of your mouse ghosting on the taskbar and other various issues? I want to know what to look out for on the monitors I get.
also what setting is your monitor set too in terms of overdrive, premium I assume?
Just wanted to post a video of the ghosting.. I think I'm going to return it, even on premium it's just too horrible compared to my old LCD. The colors are great (at least with my untrained eyes), it's just I can't stand the effect I've grown to not have to deal with.
http://www.youtube.com/watch?v=FdZPFbAPVRk
Edit:
Here is my old monitor, which a much less ghosting: http://www.youtube.com/watch?v=jT8mM4sCMEQ
AMA on premium tends to overshoot certain colors. try lowering it and see if it gets better.
Yep, tried High and off, only got worse. Premium makes gaming a little tolerable but I'm beginning to think my display is faulty, however I don't want to ship one back for a replacement and it be just the same. It's hard to say though as all these displays are no where near me.. Do those videos look abnormal ghosting though? I think I might just pay the restocking fee if I have to and get the vg248qe. Color is good and all but I'd appreciate fluidity more anyway.
your video looks like typical VA panel behavior. i'm afraid replacing it won't do any good, that's just how VA is, but IPS isn't much better. if you want no ghosting you'll have to go for gaming TN panel.
Yep, I just returned it, and am getting the Asus VG248QE. Going from a 5 year old LCD panel I guess I just figured I coudl get a bit more colors but apparently tech really hasn't advanced much since then in the flat panel department (apart from those fabled OLEDs from Sony). I actually got motion sickness a bit after trying to play games on that VA panel. I can't wait for this new monitor.
I have the 27" version of this display. How are you guys dealing with the black levels? I see quite a few people talk highly of it in that regard but its washing out so much of the detail for me. Well lit scenes look quite nice but shadows and dark scenes tend to be solid black. The only way for it to not be that way is to set it to the Photo, Game, or Movie preset and those look quite bad in color.
I remember reading that these were going to come out with flicker free technology. Is there anyway to verify youre getting one of the newer ones? Or is it just pulling the trigger and hoping for the best?
There's no real reason to get a 2x50 model now that the 2760 has come out. The 2760HS is guaranteed to be flicker-free. The later 2760HMs are flicker free too, but the first manufactured batch uses PWM. I don't know about the 24'' version.
Consider the EW2740L too, as it uses the same panel the 2760 does. There's a 24'' version as well. All new BenQ models are guaranteed to be flicker-free, they're really pushing hard on phasing out PWM.
