Its not monitor specific. Its a well known NVidia/HDMI problem.Does this also work with the Benq?
http://www.tftcentral.co.uk/reviews/dell_s2440l.htm
The made an interesting point about using HDMI and Nvidea -
"When connected via HDMI on an NVIDIA graphics card the screen by default will not look right, and the black range in particular is poor. In fact we obtained static contrast ratios of only ~400:1 in the default mode before making this change and originally thought the screen was at fault. In fact you need to go into your NVIDIA control panel > adjust desktop colour settings and change "digital colour format" from the default RGB to YCbCr444. You will notice that in the OSD of the S2440L the "input color format" option in the 'color settings' section has also automatically changed to "YPbPr" instead of RGB. This improves the colour and black range significantly when using HDMI on this screen, allowing us to obtain the results in the next section."
I'm sick of editing my drivers to make them work properly.
Does this mean a DVD/Bluray player thru HDMI thru the monitor wont look as good as if played on a PC thru DVI or VGA?
1. Limited/low + limited/low = just right but 16-235
2. limited/low + full/normal = washed out image
3. full/normal + limited/low = crushed blacks, darkened image
4. full/normal + full/normal = just right 0-255
Is there much differnce in practice between 16-235 and 0-255 when properly setup? - can u see much of a difference? I was going to get DVD player rather than use the PC dvd device. Not sure now if it such a good idea.
Hi, I need a new monitor and I was thinking of getting the GW2450HM or the IPS235V-BN.
Would you recommend the GW2450HM over the IPS235V-BN? (Essentially for rts games and movies).
Beautiful! And thank you for that, sorry for missing the first post.
TFTCentral - "....In fact you need to go into your NVIDIA control panel > adjust desktop colour settings and change "digital colour format" from the default RGB to YCbCr444....... " ... And they are retarded for doing this. It's the wrong way to address the problem........
T.
All the reviews in the world amount to nothing when you have the screen in front of you, like I did. I used the prad.de ghosting test, which uses a red block on a grey background.
It does this deliberately because this kind of transition isn't helped all that much be overdrive. And believe me, AMVA vs IPS ghosting is a very one-sided competition. The IPS wins every time.
Or don't believe me, take your pick I had one of these Benq screens and I'm just telling you what my eyes saw.
I'm not actually saying that the ghosting on AMVA makes it a bad panel. I had fun playing Portal 2, although that's not a twitch based FPS by any means. What I am saying is that AMVA is not close to IPS for ghosting.
Hi guys.
Thought I'd share my experience of the GW2750 - which I've owned for one day : buy two and send the poorer performing one back .
But seriously, I bought two of them to replace my 22" Asus dual display setup, primarily because my eyesight isn't what it was and the 1080 v res is ideal.
First impressions. Wow! Grabbed a copy of Avatar and watched it full screen. Incredible (in comparison to the Asus) colours, excellent contrast and black levels. Really a joy to behold.
But. Today I once again became a grown up and in the light of day on the monitor on which I viewed the video, I evidenced the green lurgy. Yup, a horrible zombie tinge. I hadn't noticed it the night before because I was simply wowed and I like Jack Daniel's . Consequently I have spent most of the day seeking a solution, mostly achieved through reading every page of this thread.
Now, I'm not a monitor or colour calibration specialist but I need to achieve as good a 'true' colour match as possible because my profession requires a good eye for colour both on and off screen. So... the green had to go. I tried fiddling with the monitor control panel and setting RGB, dropping the green and blue values but the green simply wouldn't go. I came closer to a resolution when I adjusted their respective brightness and gamma levels from the nVidia control panel but as darkness fell and I re-entered my office, it was still clearly evident.
It was only once I'd downloaded the interactive monitor tweaker SoftMCCS and adjusted the green black level that I hit the jackpot. As I say, because I'm not a specialist, it was a hit and miss affair guided almost entirely by the ensemble of knowledge on this forum - and for that I thank all contributing members.
Now, back to my tongue-in-cheek Tip of the Day and its relevance. The other identical monitor out-of-the-box required only reducing the Arctic blizzard whiteness by 50% and offered beautiful and, to my eyes, accurate colour resolution.
The moral: the Benq GW2750HM seems to be something of a lottery when it comes to QC, but it can be set up to offer (in my view) great colour fidelity. You just have to know how.
As to the afterburner firmware failure, I can't comment but I shall report back here in a few weeks to update this post once both monitors have bedded in.
Once again, thank you all for your help. I now have two excellent colour matched displays.
It has a very positive review over at tftcentral and i am totally sold. What do you people say about this monitor is it good or bad experience matters a lot in this space.
PWM Flicker
Well I sent my GW2450HM back under warranty after 3 months. I use mine soley for Media Center tv/dvd viewing and had come aware that under certain circumstances eg moving face against dark background I would see a bright red motion blur unrelated to the source. Other wise has been fine. WIll report back what happens.
Any one buying this should look back at my #535 to see if they too have the strange red motion issue.
Returning a monitor because of an obvious color/ama calibration issue. NIIICEEEEE
Not quite sure what you mean by that? It wasnt obvious at all & I m not sure if it was there at the start. Watching TV/DVD isnt a microscopic acvtivity & the "defect" required special circumstances for it to be obvious. Mostly it was a slight red outlining easy to miss. It wasnt a calibration issue on my part - No amount of calibration removed it unless you mean turn down all the red.
http://www.flatpanelshd.com/review.php?subaction=showfull&id=1297345519
The response time on BL2400PT is not very fast even though the monitor has a Overdrive system called AMA. I saw visible trailing in fast paced games and I don’t think the most discerning gamers will be satisfied by its performance.
Before calibration I also noticed green overdrive trailing. Overdrive trailing is the kind of trailing where you see a halo-like effect around moving objects – for example a football player moving. After calibration I managed to reduce the overdrive trailing to lower level by changing the RGB settings (the color settings can change the over shoot looks caused by overdrive systems).
You can also deactivate the AMA system to reduce overdrive trailing but then you will experience a higher level of traditional trailing (blurring on motion).
The BL2400PT uses the same panel as the GW2450. You were likely having a RED overdrive trailing, solved by lowering the AMA setting and adjusting color in order to have a black overdrivetrailing as intended.
Unless you think the BL2400PT has updated panel its not really the same as GW2450HM. Not after looking at the Prad review anyway. Much slower response time and better in other areas. Its probably the same panel as the Samsung discussed previously in this thread.
Nifty. It has a good stand and decently priced too. When looking around I saw there is a BL2410PT coming out now also.The M240HW02 V6 is the same panel of the GW2450. This firmware version gives the BL2400PT the same "premium AMA" that makes the GW2450 so good on reviews.
web browsing, e-mail, Office docs, movies>GW2750HM
casual photo editing>U2412M
Funny part is your usage scenario favors the 27" koreans from ebay over any of your choices> better IPS panel, higher resolution, lower input lag.
Acer G276HLDbd
