The open area with this hole pattern is about 40%. Same as the M1, and Lian Li more generally, uses.Did you consider other holes patterns? I am no expert, but even there is a bunch of holes, it seems you are at no more than ~50%(?) open surface area. I would think it could restrict airflow a bit, or is this within normal?
Would a more open pattern be less restrictive? Sure. I think this pattern offers a nice balance of aesthetic appeal and performance, though.
Apart from the coolers compatible with the M1, there are a few shorter tower coolers right around the 145mm height limit that use 120mm fans:I am not much for watercooling, what is the best tower aircooler that would fit the current design?
The H7, in particular, seems like an ideal choice, with a thicker heatsink than the other two.
