Before asking NCASE about Micro-ATX...
Hi Necere,
Will it be possible to optionally mount 280 mm rad on top in case of mATX motherboard using?
Sure, but because of the extra length you can't do a 280 on top and in front. One of them has to be a 240 (or less).
A couple of size comparison mockups:
I like the one on the left :)
Anyhow , kenz2centz is that in shopping for mini itx boards I found that I hated cubes and almost all mfg cases itx were BIGGER than the nCase .
Most mfg microATX cases are BIGGER also - they are just starting not making room for 6/3.5 and legacy 5.25 drive bays . They are not any smaller than the original ATX Lian Li A05N - so I stopped shopping mATX ..cause I could buy the A05N in that size and like nCASE can get in rare silver still .
I would start by staying pure .. same as nCase m1 but with room for MicroATX board then adjust for 240mm RAD spacing front and top . Having a choice between ATX Compact 150m , SFX-L or SFX is great too ..if any one goes small on the PS they have some more room for reservoir or pump..but case purchase may not have to trigger a SFX PS upgrade.
Kenny
Flexible layout, lian li construction, this is 100% in the spirit of the M series a we know it, and I feel it should look the part. You can, of course, release a non-M case at some point, with unique styling as compared to the Ms, but this shouldn't be it. Everything about this screams M1: The Sequel, and it should be recognizable as such. Alternatively, perhaps you could release updated swappable panels for the M1 to match the rounded style of this one? Perhaps with a bit of extra space in the front for something like a 120mm fan.
I'm sorry if this has already been asked, but would it be feasible to have a bracket mounted on the side over the motherboard like the M1 uses, for things like 3.5" drives? Would it fit vertically between the front rad and over-mb psu mount?
I agree - I think this case does for ATX/mATX what the M1 did for mini-ITX, and with similar styling it's well-suited to carry the M series name.
Nah. Having different exterior designs based on the same chassis sounds nice in theory, but you can't optimize things the way you can if everything is tailored to a specific design.
In principle it's feasible, though it might make more sense to design a HDD cage such that it can mount not only to the front and top fans mounts, but also the floor of the case.
You know people will build in this in multiple configurations, maybe some you haven't even thought of. Having as many options for drive mounts makes it all the more flexible.
No side bracket. The top and front of the chassis provide flexible mounting for components instead.
Hmm... What if both are already occupied with radiators?
Mounting components on a source of hot air doesn't sound like a good idea... The floor could work, but it would introduce extra ways for dust to enter the case. Incidentally, in the SFFN topic you mentioned that the case "won't have any side vents, in part so it can have a window". Why not make the window optional? I, for one, wouldn't want it.
From the very irst post in the SFFN topic you mention above:
Preliminary specs:
Dimensions (H x W x D): 350 x 180 x 380mm, 24L
CPU cooler: ~145mm
Motherboard: inverted ATX, 8 slots
Front fan mounts: 2x flexible 140/120mm
Top fan mounts: 2x flexible 140/120mm
Rear fan mount: 1x 92mm
PSU: SFX/SFX-L, flexible mounting
Radiator support: Up to 1x280 in front + 1x240 on top
Drives: TBD
Window: optional
Seems like Windows have all been replaced by tempered glass in all but the cheapest cases. Maybe you could supply some metal pins with a flat base that could be glued to a pane of glass? Something DIY that just gives you the basic connectors and let's you run with it.
Just out of curiosity ...
When flipping rads and fans, so that the rads are mounted directly to the case, there will not be enough clearance for a 280 front mounted rad, I guess.
Would slim fans help?
I don't like the way glass is usually implemented with the screw caps protruding, but there's probably a reason everyone does it that way. I'm guessing your suggestion won't leave enough surface area for the glue to stand up to repeated removals and/or won't look very nice, since you'll be able to see any irregularities in the glue through the glass.
I understand glass is more premium, but is polycarbonate so bad? It gives you more options in terms of shaping and securing it.
With a 280 on the front you have to put the fans first, because there most likely isn't enough room between the floor of the case and the I/O at the top for the rad. But it might barely be possible to do two 280 rads using slim fans at the front:
It depends on the rad, though. These particular rads are 316mm long by 30mm thick.
What's max GPU length if only mounting AIO rad to top of the case?
Somewhere around 320-325mm for the fifth slot.
Any updates? The suspense is killing me. I'm eagerly looking to "upgrade" from ITX since my Ncase M1 has been mostly stationery during its short life.
I understand the worry about calling this an "M" and using the M1's design, But you guys only have 1 product as of now and people know that style.
I say make this the "M2" or what ever and have the third one be the one to break with the look.
looks like this could be a good replacement for my Fractal Define S, so that both my ITX and ATX systems would share a style.
Nothing new to report at the moment.
I tend to work on things sporadically as inspiration/motivation strikes, rather than steadily, and often one project will get set aside to work on something else (or just to do something/nothing else altogether). But the ideas are there, simmering in the back of my mind, my subconscious chewing on a problem until it gives me a clear direction.
I know that's not very satisfying, that most people want to see steady progress being made. I just don't work that way, and nothing kills my creativity faster than feeling obligated to produce. That's true whether it's by being paid to work, or just through expectation. (There are in fact studies that show this to be true, and IMO it's one of the factors that goes into why a lot of Kickstarter projects fail to deliver).
For a similar reason, I have misgivings about showing concept designs or works-in-progress at all. It's rewarding if people tell you it's great, but that reward is coming before you've actually produced anything significant. Getting that premature reward is going to diminish your motivation to continue. That might not be true for everyone - people with addictive personalities who can't get enough, say - but it's true for me at least. I'd say it's better for me, personally, to keep creative projects a secret until they're done. On the other hand, with a project like this, it's useful to get input from others as well. So there's this opposing tension in the forces at play that makes it a less efficient process than you'd want.
I'd say be patient, but what I really want to say, is to give up any expectation or anticipation at all. That way you can't be disappointed. Then when good things do happen, however long it takes, it'll be a pleasant surprise.
IMO, the only advantage with glass is scratch resistance, but AFAIK polycarbonate can be treated for improved scratch resistance as well. In every other respect I can think of, polycarbonate is superior. I don't consider glass being "premium" in any way, it's just old tradition, superceded by better materials long ago.
I think the tempered glass fad is utterly ridiculous. Borderline stupid.
The same goes for my glasses, I quit using traditional glass back in the 90'ies and definitely don't regret it (except slightly for the need to be careful with scratches, but glass is in no way scratch proof either).
With ThreadRipper upon us, I have gone through this thread again...
I now envision a two part Ncase chassis scheme...
Chassis one - the Ncase "Original Gangster" M1 - DCC Workstation
ASRock AB350 Gaming-ITX/ac AM4 motherboard
Ryzen R7 1700 CPU
32GB G.Skill TridentZ Series DDR4 RAM (2 @ 16GB DIMMs / 3200 / CL14)
1TB Samsung 960 EVO M.2 NVMe SSD
RX Vega 64 GPU
600 watt Corsair SF600 SFX PSU
Custom full EKWB water cooling loop for CPU & GPU
- Supremacy EVO CPU water block (Acetal+Nickel)
- FC Radeon Vega full-cover water block (Acetal+Nickel)
- CoolStream 240 PE radiator (38mm thick)
- DDC PWM pump (stock barbed top)
- ZMT tubing (matte black / 10mm ID x 16mm OD)
- barb fittings (black)
- 90° fittings (black)
- tube clamps (black)
- Two (2) Vardar 120ER fans (black / 120mm x 25mm)
FrozenQ reservoir
Chassis two - the Ncase "New Hotness " ATX chassis (when available) - DDC Render Box
ASUS RoG Zenith Extreme ATX TR4 motherboard (or mATX if anyone makes a quality TR4 version)
Ryzen Thread Ripper 1950X CPU
128GB G.Skill TridentZ Series DDR4 RAM (8 @ 16GB DIMMs / 3200 / CL14)
Three (3) 1TB Samsung 950 EVO M.2 NVMe SSDs
RX Vega 64 GPU
800 watt Silverstone SX800-LTI SFX-L PSU (mounted in bottom of chassis, over motherboard / CPU)
- FB ASUS Zenith Extreme monoblock (Nickel)
- Two (2) CoolStream 240 PE radiators (38mm thick)
- XRES 100 Revo D5 PWM pump / reservoir combo (mounted horizontally from top radiator / between top radiator & GPU)
- Four (4) Vardar 120ER fans (black / 120mm x 25mm)
The M1 Workstation would be upgraded with a Ryzen 2 CPU & Navi GPU (when these come available; GPU fitted with full-cover water block); at that point the RX Vega 64 would come out of the initial M1 Workstation build & go into the Render Box build...
And those are my mad ramblings about that...
I think Tempered glass looks great, especially compared to the pathetic plexiglass windows that have been in use for years.
I'd say no window or Tempered glass only nowadays!
When I think 'windows' I picture small sometimes irregular cutouts not even centered on the panel. The full glass panels look so much sharper and cleaner.
Never say never. Even if it is acrylic or without a window, there's always enthusiasts that will mod it for tempered glass. Now I have to admit that I prefer glass over acrylic (plexi), but I understand the manufacturing and shipping challenges involved here. I would hate for Necere to get so caught up in trying to make glass happen that the case never takes off. So I'd rather have case without a window or even acrylic, then no case at all.
As a consumer, I prefer tempered glass, as it's more scratch resistant, and more aesthetically pleasing (the reflections and retractions look better, subjectively).
However, (good) mounting of glass is more limiting to case design. And manufacturing, handling, distribution, etc will likely be more costly.
To simplify the # SKUs, and lower price of admission, I rather have a windowless M5 case. I'm going to mod it with a custom cut tempered glass anyways. :p
I don't like Acrylic and Plexi, and I don't want to spend my time on those options, just don't have the enthusiasm on a product level. For the sake of discussion, let's just remove these options from the conversation.
Don't get fixated on the name "glass". A lot of glass panels are not 100% glass, they have other material mixed in or layered in, such as Polycarbonate. That being said we might be able to get a mixture material that is as scratch resistant and looks better than glass.
A lot of you are familiar with Gorilla glass on cellphones, that's not 100% "glass" either. I prefer something similar, a glass layered mixture combo - 1) lighter than tempered glass, 2) more damage resistant, 3) more translucent than tempered glass, 4) anti-fingerprint (oleophobic) coating. It also looks and feel more premium than tempered glass. Likely more expensive than glass, but worth it imo.
If we are going to offer a windowed option, I want to do it justice.
Maybe I'm spoiled by smartphone advancements, but most tempered glass I see on cases feels outdated and some of them feel cheap.
I'm usually against windows, but in this case I'm OK with it as long as it looks as least as good as tempered glass, instead of a cheap piece of injection molded plastic, like most non-TG windows in commercially-available cases.
I have to wonder though, how much a piece of PC/laminated glass/etc. of that quality and size that would add to the cost.
Have to get them made to know.
The other issue is is mounting, I don't like how full tempered glass is mounted right now (with the thumbscrews protruding).
Part of the reason I'm in favor of a glass/plastic mix is to fuse the mounting studs into the transparent panel, so no protrusions. They do them in smartphones, metal female threads are fused into the smart phone LCD screen module for mounting.
So, let's take a couple of modded M1s as an example of what a window could look like on this ATX case (since the exterior design is similar).
First, a window mounted into the stock side panel:
Second, a full side window, completely replacing the side panel:
Looks okay, right? Not so fast. Look at it from this angle:
Note how the window doesn't sit flush with the front panel. This is exactly what I want to avoid. Unfortunately, I don't see a way around it with this design. Glass is necessarily thicker than aluminum sheet, so there's no way for a full side panel to sit flush. Do you see the problem?
To echo w360, I also don't like the reliance on thumbscrews for mounting a full side window. They're like warts on an otherwise clean design, but I don't think I've ever seen anyone come up with a good alternative to them for mounting.
You could do a slide in window and a small flap at the top. That would solve those problems, there would be a very slight edge of it but it would eliminate the screws.
Another problem I have with typical windows on cases: dust. It looks awful when lit.
As for mounting, maybe there are inspirations we can take from real world architectures, something like minimal metal framing, some sort of gasket, no rounded corners.
Slide in how, though? And how do you do that, while retaining compatibility with a non-windowed panel?
Something like this maybe? Cross section of side panel, window, frame and top panel looking from the front/back of the case.
But then what do you do at the front and the back? Because the chassis flanges will be there, right? They'd have to be set in to allow room for the glass, but then it would leave a gap with a non-wnidow side panel.
I'm also not sure it would fit with the rest of the design.
I'm not sure I follow. What do you mean by chassis flanges?
My problem with a side window is it would remove the one place designed for filtered, fresh air intake. I'm not will to ruin the thermal design of my case in order to see blinking lights.
The flanges on all four edges of the chassis. This is where you've got the clips for the side panels in the M1 (and this case).
Unlike the M1, this case won't have any ventilation holes on the side panels.
I think I get what you mean. The flanges are still there, just not shown in the drawing since it only depicts the cross-section. The side panel isn't just the top and bottom, it still has the sides.
I guess the challenge would be how to make the window/grooves detachable.
Okay, so it's essentially just the side panel with the window in it, like the first M1 mod above. I guess the what you're getting at is to try to slim down the panel sections to be as narrow as possible?
I was thinking something more like the s340 Elite where you have the glass push into it similar to the current design but the panel has the push pins installed on them with some kind of adhesive. Then you can use a black border (similar to s340 elite) and hide those insertion points along with a thin piece of foam padding. The only issue would be that when you pop it off, would the screw holes detach, but I am not sure what material would work with something like tempered glass.
Ill draw something up tomorrow and post here.
Again though, the side panel won't be flush with the front panel where it wraps to the side. See the 3rd pic of the modded M1 above.
The S340 can get away with it because the front panel is completely flat, and the side panel comes right up to the edge. There isn't a jarring transition between them like there would be on the M1 and the M5 (the name I'm tentatively going with btw).
Use thicker pannels for the case?
