- Jul 21, 2004
I'm not sure how you are insulating them electrically, but the current loop occurs via the fluid.
Negative, ghost rider.
The fluid is only one half of the current loop.The aluminum and copper have to be electrically connected (aka share the same ground), for galvanic corrosion to occur.
In my case, the aluminum reservoir and the copper rad can both be isolated using plastic mounts.
I certainly do appreciate the concern though.I'm going to make sure I watch things carefully for the first while.
