Blazestorm
- Jan 17, 2007
The game is not supposed to be realistic... get over it...
I was playing on Atacama the other day with some of my clanmates and two of them were in the chopper. I must have darted them half a dozen times and everytime they disabled the dart so I could'nt get a lock on. What settings do you have to have for this to work? I think you have to hit the right mouse button for counter measures.
what is wrong with what he said? he is acknowledging that the PC and the Console can't have the same exact gameplay and that he won't make them so. What he said is pretty much true.
Because the moron said all guns should be the same accuracy, but lose power over distance. That is the dumbest thing I have ever heard. You should not be able to hit long range targets with your SMG just because you aim your sites at it. That's one of the things that always pissed me off about this game. When SMG's and LMG's snipe you at long distances better than the assault rifles. At least now I know it's because of idiot programmers who know nothing about guns instead of a glitch.
So I discovered today that the M249 is literally a headshot machine. I had something like 5 or 6 headshot pins in one round. 200 rounds and insanely accurate. Doesn't even matter that it's the weakest LMG if I can land them on the face more often than not.
The ironsights aren't as nice as the T88 or XM8 LMG sights, but I managed to dominate with them and keep my super-sprint![]()
Uzis great. Its my weapon of choice as an eng.Uzi's better than you'd expect, it turns out. On paper it's maybe not the best, but seems to knock people down better than a lot of the others. Nobody seems to have noticed this.
They need to remove that invulnerability all together. If you're resurrecting someone in direct line of fire you should be spanked. So they're "fixing" hit registration again? It's been totally fine...except for point blank slug shots with the shotgun and the knife...which they don't seem to be doing much about. So in essence, they're doing nothing.
Patches are good though.
is the bronze star all weapons still broken? or do i have to bronze the paddles and repair kit ??
Well this patch is nice and all but when the hell are they going to fix the joining servers problem? Its really annoying to sit there and see a server in the server browser and not be able to join because of "Not able to connect to server"
I'm curious as to what server they want you to tracert to? I too have been experiencing problems the past few days.you want to know whats sad.... i think all the server issues have to do with MOH. Because i didnt have this issue until last week when MOH came out. I tried contacting ea about the issue but when i ran a tracert like they said for me to and posted the results they said that issue was with my isp when clearly the trace rt shows dropped packets after it enters ea gateway (edge01.abn-iad.ea.com 50% loss 4/8)..... tried explaining it to the ea tech but she wouldnt listen / understand just kept saying it was my isp and i need to call them to open the ports.... In my exp. EA tech is useless and they wont do anything to fix their broken crap..... anyways thats my 2 cents as to why this is happening
Hey guys, whats the quickest way to level? i get around 200 pts per match and it would forever.....
Can anyone post Patch Notes?? Blocked here at work.
Thanks!
Seems as though that's only some of what they are planning.zh1nt0 said:
- One of the Insignia's requiring an unobtainable Bronze star for the tracer dart – requirement removed.
- Hit registration changes brought over from MOH to BC2; several bugfixes, the client<->server send rates have been increased, some of the hitboxes themselves have been changed. This will increase the accuracy of guns, but will not make much of a difference to the knife.
- Removed the blue box behind the chat window.
- The 2-second immunity when spawning/being revived can will now be immediately remove either by firing, zooming, or any movement (move, crouch, jump). Merely looking around will not remove the invulnerability. In essence: If a person moves, he is never invulnerable.
- 3D vision fixed.
4 things:Hey guys, whats the quickest way to level? i get around 200 pts per match and it would forever.....
Thanks, I will be running that test when I get home tonight.easo.ea.com is what the rep had me ping.
currently running the pathping right now will post later what the results show
Snipers usually sit in one back corner of the map cutting themselves, complaining that MCR just isn't the band they used to be and wishing they were another class.
4 things:
1. Do the thing that your class specializes in, and do it often. If you are Assault, drop ammo boxes next to every guy you pass, especially squadmates (more points). If you are a Medic, drop health boxes next to every guy you pass, especially squadmates (more points). If you are a medic, revive the guys close to you (especially squadmates for more points) AFTER you have cleared the area for enemies. If you are an engineer, stick close to or operate a tank or chopper to repair damage, especially if there is a squadmate using it (more points). If you are a Recon, throw motion sensors often (1 at a time can be functional), each time a guy is spotted by your motion sensor and is killed by you or a teammate, you get assist points. Doing each of these things a certain amount of times per round also gets you awards on top of the points you earn for doing so (see#3). The Assault and Medic class are the easiest to gain points while following this method since the ammo boxes, health boxes, and defib paddles recharge quite often.
2. Spot. Spot. Spot. I can't say this enough because so few people do it. Use the Q key everytime you spot an enemy. If they are killed by you or anyone else while spotted, you get assist points. The only time you shouldn't do this is while your in close quarter combat where you are too busy.
3. Awards. Check through your awards page and try to get as many awards as possible. You can get bronze, silver, gold, and platinum stars for weapons. Most of the awards are worth 5000 or 10000 points. I average 3000 - 4000 points per game as an assault or medic, almost all of the points I earn are from awards.
4. Assign Attack/Defend orders with the Q key. I believe you have to be a higher rank to do this (??). Simply put the objective in your crosshairs and press Q and it will put red crosshairs on the objective. Other teammates might change this on you, but that doesn't matter. If you kill a guy while near the objective you are attacking/defending, you get bonus points, even if the Attack/Defend order was assigned by someone else. Hardly anyone does this. I find it a great way to add more points. I will always assign orders to an objective when I approach it, free points every time I kill someone.
