- May 18, 1997
Lots of inches and lots of power. Might work great for a porn movie, but it is going to be tough on the computer enthusiast.
Please Digg to share.
Wow...stupidly long and more hungry...
It better be at least 30% better than the G80 to even be considered...most people will have to upgrade their cases for this...and the SFF club had some hard time with the G80...no chance with this.
Wow those who were complaining about those who were complaining about size need to shut up now i think lol. Thats a big card.
As far as upgrading to that? F that. I wanna keep my good PSU...
who needs SLI anyway
HOLY SHIT!!!!
thats 300watts max load for the r600. I can run at least one on my hx520. who needs SLI anyway
FOR HEAVENS SAKE THIS IS THE OEM VERSION OF THE CARD. THE RETAIL ISNT GOING TO BE THIS LONG!!!!!!
Sorry about the caps, but people bitching about the size is getting irratating as all we seen is the OEM version with the extended heatsink.
HardOCP Thread Article said:ATI is stating that 345mm / 13.6" will be the required space to fit the cards in a case. This figure is the card's 335mm physical length plus 10mm to properly install the card. A GeForce 8800 GTX is just under 11 inches longs while the 4 GPU 3dfx Voodoo 5 6000 comes in at 11.75 inches.
Nope buddy, you're wrong... this is the retail apparrently:
Ha. Told you.
This had better perform 40-50% better than an 8800GTX.
Im still holding my judgement. Call me stupid, optimistic whatever. That clearly looks like a OEM case with all those quick release rails, etc. It be stupid for them to release a card that long where its going to be a tight fit in alot of cases. They didnt specify what version of the card going to be 13.3in, so im holding my judgement to release.
As you can tell that is a server case, as those are most likely Opertons as I see 2 processors on that motherboard. I just cant see how they expect to sell this card where its going to cause alot of fitting trouble. I dont know many cases that are that long without bumping into the hard drive cage.
Also look at this pic of the card http://blogs.zdnet.com/Berlind/images/ATIR600topBLOG.jpg , you can tell the fan goes way past the end of the PCB, I'm pretty sure the retail version would have a smaller fan.
Damn! I knew i should've bought a beefier power supply when i had the chance. Now it looks like i'll have to buy another one.
Pwned.
I'm not getting good vibes from ATI's recent announcements. Earlier the X2900 was starting to sound like the FX5800 Ultra, now it's starting to sound like the bloody PS3.
That is the OEM version of the card. It will only be available to manufacturers. This info has been around for a while now, I'm surprised none of you have kept up with it. The retail version of the card will be a little over 9 inches long. That article only gives you half of the info. The retail version will also require less power. Several different sites have reported on this already.
Actually I don't. That is what has been reported already. If the reports from the sources are incorrect then that is not my fault. Like I said, I'm surprised you guys are so in the dark about this. It was on several tech sites including Dailytech. If this site is your only outlet for info, then I guess that is the problem.
Eh, I think this is just Hard Fud.
You know how pro-Nvidia Kyle is.
And pro-AMD, but I'm betting that will change now that AMD owns ATI.
Anyways, it really doesn't matter if it uses 300 watts, if it also destroys the G80 in benchmarks. Which it probably would, if it uses 300 watts.
Anyways, I really think this is FUD. The long card is OEM and the 300 watts thing is probably a lie, I've generally read 200 watts for R600.
It's clear Kyle just dug for ways to bash ATI as he questioned the ATI personnel. Then he took two negative items and spotlighted them in this article for his agenda.
What Kyle should have focused on is the monster Teraflop power of this rig. Over double the Flops per card as G80. Let me promise you know, all those SLI guys that predominate on Hardocp will chuck their SLI rigs out the window faster than you can shake a stick for that kind of beef.
If enthusists cared about power consumption, Nvidia's power hog, EPA regulations pending, Al Gore hating, SLI wouldn't exist. It's that simple.
