Looks like areca removed the firmware from the main site now? I wonder why. Areca hasn't responded to like the last 5 emails I sent them. Not sure if they aren't getting them or what.
The firmware still in the areca ftp site.
Yes, the firmware counter is a new feature. My guess is those WD20EARS drives are what's holding it back from booting first time. ....Also try disconnecting the Samsung if the there's no change when the WD's are disconnected, since that's the only other unique drive.
I am about the push the button on getting an Areca 1280ML card.
I've only heard good things about these cards, but, in Raid 6 mode do they have any drawbacks I should be aware of? What is the magic number of hard drives this card can handle before diminishing performance returns really start to set in?
I am looking to start out with a 10 drive array of 2TB drives, with near term expansion to 15 + hot spare, and ultimately a full 24 drives creating a 48TB array.
What are your thoughts?
24 drive Raid6 is too big IMHO. I would go with 2 12drive arrays.
wouldn't the use of 2-3 hot spares help diminish that risk significantly?
Only drawback of RAID 6 is the longer rebuild time, but with that many drives you definitely want to use it over RAID 5. The 1280ML caps out at about 700mb/s for reads, so you can figure out how many drives it will take to hit that. It's a good card and I used one for quite some time until I needed more than 24 drives.
Quick question...
I recently declared a LOCAL hot spare for one of my raid 6 arrays. I've noticed that the HDD activity light is almost always lit up. Any reason why?
Might wanna check the settings. There is setting for idle drive LED ON or LED OFF that could be causing that behavior. Also with some 1.5 TB seagate drives they ha bad firmware (SD17) which would cause the disk activity light to almost always be on (not just on raid controllers).
I am atm running 12x Samsung F4 2TB drives on my 1680 + HP sas expander and i get a few timeout on random drives but atm it is about 1 time out per month or less.
^ not an expander issue. post your exact configuration (RAID level, drives per array, power management settings). most common reason for timeouts is if too low a "staggered spin up" value is set.
with 1680i + HP expander and Hitachi 2TB drives I had to go as high as 2.0 seconds for staggered spin up in order for timeouts to disappear completely when array was waking up from spindown. with 1880i I can get away with 0.7 with same expander and drives.
TIPS:
1) For proper array spindown on RAID arrays with Hitachi 2Tb (7K2000) drives, the "Stagger Power On Control" value needs to be increased to 1.0, 1.5 or 2.0 seconds. You'll need to experiment to find the lowest setting. For testing set "Time To Spin Down Idle HDD" to 1, wait a minute for the array spindown, then access the drive with the array data and wait for it to spin back up. Watch the event log for any drive timeouts- if you see any, you'll need to hard-reboot the computer and try a higher stagger power on value (i.e. try 1.0, then 1.5, then 2.0 seconds).
Is it always the same drive that shows up in the event log as timing out? The spinup value would only come into play as a culprit for timeouts if you were spinning the array down. Can you post a screenshot of your power management settings?
is it normal that a 60TB Array (27x2TB+3 Hot Spares) took 62 hours to initialize? Seems pretty long.
Hardware: Areca 1880i-24, Astek A33606, StarTech SBAY5BK Backplanes, Samsung F4 2TB
I would think it would just mean that the array would be degraded, but when a time out happens every filesystem on the array is not accessible by the OS until I reboot the whole machine.
Hitachi will do advanced replacement if you email them and explain why you need it.![]()
Not sure if it's a bug either, but I find it odd that the Timeout Count is 0 on the drive when it's probably timed out over 5 times now.
My 24-drive RAID6 took the following with foreground initialization and default 64k stripe size:
Areca 1880i + Dual Link to HP Expander + 24 x Hitachi 2TB + RAID6: 9h 18m
Areca 1880i + Single Link to HP Expander + 24 x Hitachi 2TB + RAID6: 14h 19m
(BTW, your 3 hotspares seems like overkill, unless you were planning to leave the system in Antarctica in a weather station and not return for 5 years.)
Ok, think this might be a cross-post, sorry iff so.
Are there people here using the Hitachi Deskstar 7K1000.C drives running RAID 5 on the Areca? I see lots of people use the 7K2000 to good effect. Does the same go for the 7K1000.C? Planning on running 6 of them on an Areca 1220 in RAID 5.
Can i use them ok, or are they going to give trouble with the CCRL/TLER stuf? Hope someone can give me an answer.
They will probably work fine but you should update them to the more recent 3EA firmware. I use 4 in Raid5 with an IOP based (Same as Areca 1680) Rocketraid 4320 and they work fine, no drop outs or errors, HDTach graph isnt quite perfect but all other benches show good performance and system is responsive.
The Arecas I use are at works so I cant try the Hitachis for you on a 1212 or 1680 but I can make an educated guess that they will work OK.
Thanks. Just have to find out were and how to upgrade those 3EA firmware. I'm taking the leap, and orderd 5 7K1000.c drives ( and yet another external hdd for backup haha )
Hope to start assembling and testing soon.
Thanks so far, apriciate it.
I couldnt get the crappy Hitachi Windows utility to work but the dos utility on a dos bootable usb stick worked fine.......
http://files.hddguru.com/download/Firmware updates/Hitachi/
Plug the the first drive into you motherboard sata controller (Should be set to compatibility mode in bios)
Get the JPDL_SP.exe from the 3EA rar file
Take the BD files from the 3MA zip file and rename them to BDX
Put all of this together on a bootable floppy or bootable usb stick
Boot and run the exe, it should confirm the firmware is updated
Unplug drive and plug in next drive - Repeat
Whoops, talked to fast.
Ok, then these files i put on the usb stick are:
JPDL_SP.exe ( from 3EA file )
JP0NB3MA.BDX ( from 3MA file )
Those two, on the stick, remove all hdd's, insert hitachi, boot, run exe and ready?
Correct?
