suiken_2mieu
- Apr 7, 2010
I'm constantly refreshing newegg and occassionally checking amazon and just cant find any in stock anywhere. Is anyone having any success buying these cards?
Part of the problem is you got guys like jbean buying crap to resell along with the bots that do the same thing you're competing with.
Online venues suffer from this considerably with any high profile product release..
You'll always have better luck hitting the brick and morters.
MSI Gaming Radeon Rx 5700 Xt Boost Clock: 1925 MHz 256-bit 8GB GDDR6 DP/HDMI Dual Fans Crossfire Freesync Navi Architecture Graphics Card (RX 5700 Xt Mech OC) https://www.amazon.com/dp/B07WNSP41M/ref=cm_sw_r_cp_api_i_sRVBDbQW4XMAB
It doesn't.I thought Navi didn't support crossfire???
to me, these are all basically still reference boards. When are we going to see a third party board that does something worth more than a different heatsink like add more/better ram?
It doesn't.
DX12 and Vulkan offer API-level multi-GPU support. It works on Navi.
So I ended up getting a gigabyte 5700 xt gaming oc card. Couldn't risk the chance of Borderlands 3 coming out and me playing it on my RX480. I'm positive big navi will come out in like 3 weeks now and it'll be like 500 bucks for 30% faster card or some nonsense but whatever. that's the way it always is with video cards.
seems like it's getting easier and easier to get these online now. Not really worried about quality control in heatsink installation since I plan on re-applying it myself, which seems to be most of the differentiating issues between the currently available lineup.
Seeing that MSI Mech (which looks like their Gaming X series) instock, but found a reddit review that said it was really loud. Not sure why MSI is dropping the ball on their AMD GPUs.
Holdover from the GPP contract?
Why not get an rtx 2070 super when you're that close?The Sapphire Nitro+ has a listing at Newegg ($450 shipped) now. Out of stock of course, but you can get your e-mail on the auto-notify!
No, there are multiple that are 500, but you only need oneThere’s only one 2070 super that’s 500. Most are 550 and up. The 5700 XX is 100 cheaper.
<---- FixedThere’s only a few 2070 super's that are 500, but the only good ones are 550 and up. The good 5700 XT's are still 100 cheaper.
You don't need the super duper cooler on the 2070 supers like you do on the Radeon. The ref cooler is very good on them unlike the 5700xt.<---- Fixed
