Arctic Cooling MX-2 Thermal Compound 4g $3 Shipped
MavericK
Zero Cool
This is pretty much all I use currently...great stuff. Might grab an extra tube.
dC0m
How does MX-2 compare to the former MX-3 and MX-4? I only use MX-2, but I ran out and might need to get some more.
TheGeekFreek
Good stuff, Started using this over AS5
Works just as good, spreads easier, not electrically conductive.
Retsam
Id be all over this if I needed some.
I still have AS5 from like 5 years ago with plenty left, a tube of that shin etsu stuff, as well as that generic cooler master stuff that comes with my Hyper 212+. : /
MavericK
Zero Cool
I really like this stuff because it works better than AS5 and is not conductive. I can't say whether or not MX-3 or MX-4 is better (one would think it is, though), but this stuff is plenty good. Any analysis of performance increase beyond this and you're picking nits.
syn0s
Thanks.. picked up 2, even though I have some Hyper 212+ stuff and some AS5.. can't ever have enough TIM!
MavericK
Zero Cool
That was fast, I ordered one a couple hours ago and it's shipped already.
MrMike
Same.
After the first few orders they probably had someone sitting there with a box of them and a case of small padded envelopes. :p
Insula Gilliganis
MaximumPC recently tested the MX-2 and wrote..
The predecessor to Arctic Cooling’s MX-4 is slightly lighter and slightly thinner than the newer compound, but is also non-metallic and electrically non-conductive. Its performance was almost indistinguishable from MX-4—well within the margin of error. It’s also a few bucks cheaper, so if you’re especially budget-conscious, go for the older but cheaper compound.
Geek Approved?: Yes
Unfortunately the MX-2 isn't listed in Hardwaresecrets' monthly "Thermal Compound Roundup" but the MX-4 is.
XacTactX
http://skinneelabs.com/2011-tim-results/
MX-2 is a hair better than MX-4, but it really doesn't matter because they are practically identical. If you aren't a stickler for 0.25* C, you can get a 25g tube of Ceramique 2 for about $10 on eBay. It really depends what quantity you want, but either way this is a great deal.
Good find OP, thanks for posting. I wish I could make an excuse to get some.
yankee495
I'm in for two! Thanks...
Using TX-2 now...some say it is better...someday I may find out.
Kueller
I only have a little AS5 and shin-etsu left in each tube, guess now is as good a time to restock as any. In for 2!
NoNRG
F*&# me. I'm using Shin Etsu G751. :eek: lol
DuronClocker
Eh, just ordered 3. Even a single tube will probably last me a couple years, but figured it'll be a loooong time since I have to use stock paste again now.
Ferdjones
Just ran out of AS-5, so this is a good time to get more thermal paste. Thanks op, got 2.
sbinh
In for 3 .. used Mwave rewards .. knock the price for 3 to $5.49 shipped .. :D
Thanks.
NickJames
What's the shelf life of thermal paste? Does it tend to harden or something over time? I bought 5 packs last time it was on sale haven't used all of it so just curious.
Unknown-One
AS-5 isn't electrically conductive. Go ahead, try using it to draw a trace, it wont carry any electricity.
Yes, AS-5 is full of highly conductive silver, but the silver particles in AS-5 are encapsulated in non-conductive oil. At worst, AS-5 is very slightly capacitive, but only just... you could slather it all over circuits and bare contacts, and never have a single issue.
