Apple 27" LED Cinema Display
Discussion in 'Displays' started by rezonat0r, Mar 19, 2010.
  1. the_real_7
    the_real_7 [H]ard|Gawd
    1,031
    Sep 10, 2007
    After playing with this baby I wanted to get up some screenshots of a really good screen , maybe it aint got 120 hz going for it , but it sure got plenty of detail at 2560 x 1440
    " notes : if you have a tn these shots probably wont look as good to you when viewed ;) "
    you will see a lamp behind me , which i realized , and moved after photos ,becuase man i love glossy , but damn Apple you took it to a mirror level , so wonder matte people talk . . glossy with polarizers don't reflect like this at all :) but now is all good place lamp in front of desk . screen back to greatness , took all with a high quality Sony Camera
    my rig setup to push this resolution hungry bastard . . .
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Desktop HQ wallpapers
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Game Shots at 2560 x 1440 HQ
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  2. zod96
    zod96 Suspected BAD TRADER
    2,709
    Feb 23, 2008
    Awesome setup man! Did you have any problems setting it up? I mean was it just hook up to display port and you were good to go? And you can control the brightness and enter the bios and see the boot screen as well?
  3. the_real_7
    1,031
    Sep 10, 2007
    Thanks Man , I like it alot , well actually setting up was a bit of learning experience , yes its plug and play , but brightness work in two stages , one is the backlight which works separate from your color controls in your video card and use apple control panel with some fixes , setting of the backlight comes at 50 percent from factory , you need it to be at least up to 60 65 percent to get a gamma of 2.2 and get 6500k on the dot , I made a apple color profile with my Eye-One Display 2 . . . there is no osd , you can use you video card color property but man the screen is so off at beginning i highly recommend a color-meter or you can get a copy of my profile ;) . . . you see the boot screen perfect, works like a normal screen in that aspect
  4. zod96
    2,709
    Feb 23, 2008
    Yeah I may just go for the U2711 instead....
  5. the_real_7
    1,031
    Sep 10, 2007
    just keep in mind the AG and 30ms game lag cause of the scaling on that screen is very harsh , I would recommend a dell u2312 , got the best of everything , actually i would say it beats the apple cause of price vs performance is minus 4 inches worth 700 on your pocket , im already looking for my apple receipt lol :D
  6. zod96
    2,709
    Feb 23, 2008
    How is the input lag on the Apple? I use Vysnc when I game
  7. the_real_7
    1,031
    Sep 10, 2007
    Well it actually same screen as Hazro HZ27WC , which also doesn't use a scalling osd
    I put a diagram here of lag time , the one on the bottom with apple is incorrect tft central copied it from anandtech , and it wasn't lag time it was response time . . so your looking at 8ms which is not bad at all
    [​IMG]
  8. zod96
    2,709
    Feb 23, 2008
    I may try it then. But the other problem is my setup does not have a display port only DVI. So I would have to get another card. And when you say you need the apple control panel to change your settings what is that exactly? BTW thanks for all the help...
  9. the_real_7
    1,031
    Sep 10, 2007
    1.yea you have to get a atlona adapter , or just change up you video card for a updated card with mini display port , with this screen you'll need a bit of power i would say a 7950 would do great
    2. apple control panel is a software for apple computer but there a file here somewhere that works on windows , just take a little work around , but after that your ready to go
    no problem man , trust me it is a great screen , get the apple refurb , i got mine 85o brand new not one pixel missing and uniformity like no ips ive never seen , feel like im on a plasma ,
  10. Vega
    Vega [H]ardness Supreme
    4,674
    Oct 13, 2004
    I've just gotten this Apple in and I can safely say it is the best LCD display I've ever used. And I've used just about all of them.
    Just sent back a Samsung 27" 850D PLS screen which I feel is inferior.
  11. zod96
    2,709
    Feb 23, 2008
    So basically if I do the following:
    1. Buy a video card with Display Port
    2. Download the Control Panel Applet
    I will be good to go without a problem? Yeah I was looking at getting a 7970 or 7950 but of course they are sold out everywhere...
  12. Vega
    4,674
    Oct 13, 2004
    Ya, I've got the brightness application working within a few minutes following the instructions previously posted.
  13. zod96
    2,709
    Feb 23, 2008
    Where did you get that info?
  14. jeremyshaw
    jeremyshaw [H]ardForum Junkie
    11,700
    Aug 26, 2009
  15. zod96
    2,709
    Feb 23, 2008
    Can you use the new thunderbolt 27 inch or does it have to be the old version?
  16. jeremyshaw
    11,700
    Aug 26, 2009
    Thunderbolt 27 only accepts thunderbolt input. :( It's a one way compatibility street.
  17. Vega
    4,674
    Oct 13, 2004
    Yes thunderbolt does not work with mini-DP. Apple still sells the 27" cinema display with the exact same panel for this reason.
  18. zod96
    2,709
    Feb 23, 2008
    I'll probably buy one this weekend at Frys....
  19. elvn
    elvn 2[H]4U
    2,450
    May 5, 2006
  20. zod96
    2,709
    Feb 23, 2008
    I just hope this applet thing is easy to do :)
  21. Ashok0
    Ashok0 Limp Gawd
    507
    Jun 4, 2010
    It's pretty easy man, it's just a simple program file. Took me about 30 seconds to get it working with a shortcut using the steps provided above by _cide. If you get a mini-DP graphics card, using the ACD27" on a PC is really no different than using it on a Mac. I absolutely love this display, and if you want a 27" WQHD monitor that is glossy/semi-glossy,
    there really is no PC monitor that can compare, aside from the Samsung S27A970 which is a future product with no solid release date.
  22. zod96
    2,709
    Feb 23, 2008
    Alright sounds easier enough. Now to find a local Frys that has it. I tried my Local one here in Fremont and they only have the new Thunderbolt one, not the old. I called a few places same thing, only the new one not the old one....
  23. zod96
    2,709
    Feb 23, 2008
    Also I just want to make sure. If I go with a video card that has display port, I do not need to buy any kind of adapter correct? Its only if I use DVI that I will need the adapter correct? And if I were to buy the adapter in store at Frys which one should I get?
  24. poindexter
    poindexter [H]Lite
    88
    Jan 10, 2012
    Does the 27" ACD use PWM for backlight dimming?
    I use 27" iMacs (iMac 12,2 model) at school and they do not appear to use PWM, based on the wave test as well as some testing with a camera. I am hoping the 27" ACD is the same, as the iMac is one of the few newish monitors I can use without eye strain.
    Thanks!
  25. the_real_7
    1,031
    Sep 10, 2007
    hey zod96 me are one of us will pass you a profile , no lcd is the same they will tell you but mostly youll be off maybe under 5% , ill put up my settings later with a profile download i hope other here do same
  26. zod96
    2,709
    Feb 23, 2008
    But again. If I go with a video card with a mini display port I will not need ANY adapter to use the monitor correct?
  27. the_real_7
    1,031
    Sep 10, 2007
    " If I go with a video card with a mini display port I will not need ANY adapter to use"
    " will be better than a apple pc , i love the no more power button , set up screen off 10 min or whatever you like . . . youlll like
  28. the_real_7
    1,031
    Sep 10, 2007
    Apple club gots your back , it will be better , you just bypassed a screen processor and told your mega video card to handle business scaling and all . . . . by the way that the way it should be for speed. " um 8ms lag you screen has no processing "
  29. Pechendko
    Pechendko Limp Gawd
    208
    Jan 19, 2012
    Make sure that your hard drive is set in IDE mode in bios. Otherwise the apple control panel won't open.
  30. elvn
    elvn 2[H]4U
    2,450
    May 5, 2006
    no you can use ahci using the steps I re-posted from Cide several times in the last 20 posts on this thread..
    http://hardforum.com/showpost.php?p=1038316669&postcount=710
    BTW: My disk drives run in AHCI mode and theres no chance I'll be changing that to IDE to make something run right :)
  31. Ashok0
    Ashok0 Limp Gawd
    507
    Jun 4, 2010
    DVI video cards require the $99 (from TigerDirect) Atlona AT-DP400 converter which can be finicky regarding the BIOS and Windows loading screen. DisplayPort video cards require a hassle free $15 DP to mini-DP adapter cable (http://www.newegg.com/Product/Product.aspx?Item=N82E16812200602) and the BIOS and Windows loading screens display fine. mini-DP video cards are a direct connection exactly like a Mac. Any external device such as a Cable Box, TiVo, XBOX360, Playstation 3, etc. requires an HDMI to mini-DP converter such as the Atlona AT-HD620.
  32. zod96
    2,709
    Feb 23, 2008
    I've actually decided not to get it. Its $1000, then on top of that I would have to upgrade my video card setup to something like crossfire 7950 which is another $1000. And I also forgot my eye sight is not the best. And at that high res everything is going to look like I need a microscope to see it. I think I may be getting the Samsung S27A650D 27 inch LED MVA panel. Its 1920x1080 $400 and will work with my existing video card setup. And it does not have that AG aggressive coating like the Dell's do...
  33. the_real_7
    1,031
    Sep 10, 2007
    well actually 1 7970 would easily run the screen , most peopl score on it 12000 3dmark which surpasses 6970 in crossfire . .
    but yes the text is the smallest ive ever seen at time bugs me a lil . so the screen your picking would be much better in that sense , and would have excellent blacks , but would be a horrible for games , and the backlight bleed is a dealbreaker
  34. 123Lanoix
    123Lanoix 2[H]4U
    3,414
    Nov 14, 2005
    i have the dell U2312H and its awesome for gaming it really does have like 2ms lag
    i noticed the improvement instantly. I want to upgrade to a bigger screen size like 27"
    is the dell ultra sharp 27 " better than the apple cinema?
    btw iam using display port currently with my 6970 crossfire setup
  35. elvn
    elvn 2[H]4U
    2,450
    May 5, 2006
  36. Vega
    4,674
    Oct 13, 2004
    This Apple is a great display. Below is a comparison with a FW900 if anyone is interested.
    The best LCD (my opinion of course) Apple 27" Cinema Display versus the best CRT FW900. Both are color calibrated.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Which picture do you guys like more? The Apple is a brilliant LCD but the FW900 does quite well compared.
    [​IMG]
    As for motion, here are two Samsung 120Hz panels flanking the FW900 in Eyefinity playing Skyrim "AFK camera spinning". The FW900 stays very clear and just look at the side monitors. FW900 will appear slightly darker due to the nature of the way it refreshes and camera capture.
  37. elvn
    elvn 2[H]4U
    2,450
    May 5, 2006
    The sizes look weird in the pics that contain both the ACD and the fw900, but its prob just distance/perspective.
    I'm glad you like your ACD and your fw900. .. I totally agree they are great. Your rep and experience with so many different monitors and setups supports what everyone has been saying about each (ACD and fw900) in their respective threads.
    I've been running a few different display types for years in order to get the best of the tradeoffs, and that hasn't changed. There are too many tradeoffs for me to be satisfied with just one type.
    . Although I have other monitor setups in mind for gaming, the ACD is staying at my desk more most everything else desktop/app related. The ACD is best for the size and real-estate, ppi, color, uniformity (and geometry as well as crispness vs crt). The imagery on the ACD is gorgeous. The FW900 are best for motion on a widescreen - nothing else is even close. They also have the benefit of no native resolution, and have good color and decent black levels. For black levels on non-crt, VA lcd or a plasma are best, but those are for TV's imo, and not for games. So there are really different several different tradeoffs imo, some more important than others, and those priorities may be different for different people.
    --very high rez/ppi + resulting large desktop real-estate and crisp imagery
    -- larger size ( 27" - 30" at normal desk distances)
    -- geometry and crispness, "solidity" vs eye fatigue/strain
    -- color quality + brightness uniformity across the panel.
    -- crisp, clear, high speed motion without smearing or blurring
    -- black levels + detail in blacks.
    -- lack of bulk and "footprint", modularity/mounting
    -- lack of native resolution
    -- simplicity of setup/calibration/tweaking
    -- longevity, availability
    -- price
    ..I'll go into the fw900 setup stuff more in the fw900 thread.
  38. Vega
    4,674
    Oct 13, 2004
    Ya the Apple definitely has the size/real estate over the FW900. The FW900 is just closer to the camera and the Apple image has it's sides cut off to mirror the FW900 16:10 image makes it appear a little smaller.
  39. Pechendko
    Pechendko Limp Gawd
    208
    Jan 19, 2012
    Can you do the same motion comparison, but with the ACD in place of the F900?
  40. Vega
    4,674
    Oct 13, 2004
    I've already compared the 120Hz Samsung's vs the Apple, with the Apple having more motion blur as to be expected. It basically boils down to more blur versus higher resolution between the two as they are both excellent screens.
