Anyone use this EVGA cable management add-in?
x509
So how does this plug into a GPU card? Only their own? The B&H website doesn't explain any of this.
Zepher
[H]ipster Replacement
ya, it's designed for the 9, 10, and maybe 20 series of EVGA only cards.
May fit other cards if the power ports are the same distance to the edge where the power link bends.
x509
So if I don't get an EVGA card, then maybe I don't need this adapter card.
Dan_D
[H]ard as it Gets
It basically works with reference designs but the connectors slide around so it can be adjusted somewhat. I've verified that mine work on the Titan X, 980 Ti, Titan Xp, and 1080 Ti. I haven't tried an RTX 2080 Ti reference card but it will not work on my GIGABYTE RTX 2080 Ti Aorus Xtreme 11G.
Repo79
Yes I have and its great to use for a clean look, never had any issues with it. Highly recommend it
