While my current computer is a pinnacle of 2004 technology, it's starting to show it's age when dealing with the more demanding of tasks. Well, who am I kidding, it's being showing its age for quite some time. Now that I'm really getting into encoding (HD to x264 mostly, some Xvid) and editing, it's high time I built a system dedicated to doing just that.
While my budget is nowhere near the lines of an 8-core rig, I'm in the market for something around half that price ($1,000-$1,400 although cheaper is better), so I figure a good quad-core system would fit the bill. That being said, does anyone have any suggestions for the following:
***Processor***
While I've always been an AMD man, from what I've read, Intels are far better for this application. That being said, after looking at the results of various processors encoding an HD file into x264, I'm thinking of going with the Q6700.
***Motherboard***
I'm a little of unsure of what route to go with this. If the price is right, it would be nice to get a dual-cpu motherboard in the event I ever want to add another CPU. However, if the price for such a board is noticeably more expensive than just a single-cpu board, I'll just stay with the latter. In either event, I'd like for it to have the capability of being overclocked as I'd like to experiment with that.
***Video Card***
Again, I'm not really sure where to go with this. Think I read somewhere ATI's are better suited for x264 playback; not sure what would be adequate and what would be overkill though.
***Memory***
What type of memory I'll be getting (DDR2 or DDR3) will of course be dependent on the motherboard I decide on but that aside, how much is required for getting the best performance from my processor? (2GB, 4GB, etc)
***Storage***
I'll most likely going with a 1TB+ RAID setup for this machine but am not sure if I should also get a smaller, faster drive (10,000 or 15,000 RPM) to aid in encoding. Is the price difference really worth what you get out of it?
***Power Supply***
Again, this is dependent on all of the above, but any guesstimates on how many watts would be required for this?
***OS***
I'm thinking of staying with XP till Windows 7 comes out; would 32-bit or 64-bit be better?
Thanks in advance for any suggestions or tips.
***Processor***
***Motherboard***
***Video Card***
***Memory***
***Storage***
***Power Supply***
***OS***
