Newegg has a cheap ITX option $75
http://www.newegg.com/Product/Product.aspx?Item=N82E16813186211
The socket placement is interesting
dammit, why couldnt this have been there last friday? i ordered the gigabyte one instead.
That Foxconn one is awesome because of the socket placement. The only thing I hate about all the others out right now is the fact that basically the intel/h50/h70 stuff work. No aftermarket air cooling works
Looks like the Asus H61 board is now available. May be a good choice for those that want a more basic 1155 mitx board. Uses regular DIMMS, only supports SATA 3.0 Gbps, but does have USB3.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131727
The ASRock is a great choice IMHO. And the Asus P8H67-I (non deluxe) should be available any day now.
The Asrock don't have CPU voltage adjustments, which IMO is a HUGE deal for a low powered ITX build. The Asus does thoThe ASRock has USB 3 and SATA 6.0Gbps for $5 more.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157238
I've undervolted mine by 0.1 already by using the offset mode. It can probably go farther but I havnt had the chance to stress test it more.So far, I haven't heard of any reports of undervolting sandy bridge CPUs on the H67. Can anyone describe their success with it?
Out of curiosity, does anyone know if the Gigabyte GA-H67N-USB3-B3 can run with only 1 stick of 4gb DDR3?
theres no reason why it shouldnt. minor performance drop using single channel, but it shouldnt be too noticeable.
Thanks. Oh, and it only OC function it has is +4 on the multi, right? Is that above the turbo of 3.8?
actually i havent even looked at overclocking mine yet. :/ mines a file server/htpc so im actually gonna end up downclocking it if anything. i can check some stuff out tonight for you if you want.
The Asus P8H67-I (non deluxe) is not listed on the US Asus site. I wonder if this is another non-US release.
the only non deluxe ASUS LGA1155 mITX board I am aware of is the H61 variant, which is already avalible on newegg. No SATAIII/6gbps, however
