Big Fat Duck said:is the P180 king of cases for now?
Extreme-Killa said:nooooo.....![]()
its okay Lian-Li... you will have your day again...
***Rubs my Lian-Li case and slips it back under my feet***
CJ4 said:I have seen the CM stacker and was not impressed. It is large, but that is about all there is to it compared with other high-end cases. The P180 is impressive and much more groundbreaking than the stacker. The only reason I would ever go with the stacker compared with the P180 is if I was watercooling.
CJ
Which Fry's ?IxGOxSOLO said:Well I just picked one up at Fry's. Haven't opened it yet, just got off work at 12:30am but tomorrow will be a nice day.![]()
No... I'm definitely shooting for the black version.mohammedtaha said:Did anyone see the black version of the case yet ?
I doubt anybody has it yet... but... unf that looks good.mohammedtaha said:If anyone has it, please post pics ... It looks far too sexy for my room![]()
qdemn7 said:Which Fry's ?
IxGOxSOLO said:San Diego, CA
They just got them in. I really like the design, very smooth. That sidepanel does take some work to put back in place though. Aside from that I really like it, now I just have to get my PSU and all the other parts of my computer and I can start building!![]()
So what? A portion of every sale of the black goes to Silent PC Review, and that website has had a major hand in the whole process of pushing Silent PCs over the last few years. If Silent PC Review did not exist, then there's a good chance this case might not exist.mdlestat said:Damn.... that's $60 more than the silver one (at techonweb anyway).... sheesh---
Bepunk said:How does the interior space, air flow, and cable management in the P180 compare to the Sonata (original)?
linjy2 said:what are the case temp people been getting for this case? i cant seem to go below 40C, my old case i was 25C. granted im still using the stock 3 fans, i plan to add one more, but will this drop me to the 30's at least?
i tried 1 fan front, 1 back, and 1 bottom mid. 2 fan back and 1 bottom mid.
Both gave me 40C idle. argh, maybe its because of the low speed or something.
really i dont remember. it was in the famous antec case that every company has a version of.CJ4 said:What kind of fan configuration did you use on your old case? At what fan speed and size fans?
CJ
i plan to add another 120 to see if it drops to 30C, and i dont use the vga duct.samxuau said:Am getting 30c....
Leave all the stock fans and add another one in the front.
Remove the VGA duct.
This might help to drop the temp alittle more...
Seasonic S12 500w or 600w.notalent420 said:Newegg has it in stock for $135. Pretty good deal IMO. Before it went out of stock it was 149$. I think I have found the case I am going to build my new computer in.
Anyone know of a top-of-the-line PSU that would fit in this case. I read about how the OCZ's are not of standard size. I was looking at the PC Power & Cooling PSUs but I want to find something cheaper if possible. Anyone know if the Phantom PSUs by Antec are any good? I read they are 80% efficient. That's pretty good since most PSUs I see are 70ish.
EviLBoX said:For those of you who removed the VGA duct, did you block off the grill in the back of the case? Or just leave it open?
