http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=142
Antec has come up with a new form factor for PSUs aimed at 1k+ Watt configurations called CPX. Since it's a lot larger than the current PS/2 form factor (used in IBM PS/2 system originally, then ATX systems), it allows for more room for components and better cooling. Instead of a maximum of an 80 mm fan without using an overhead fan, a 120 mm fan fits with ease.
CPX still adheres to the ATX standard for PSUs, so it is a drop-in solution where the case supports this form factor, which is three Antec cases at this point.
Personally I wish someone would also come up with a new form factor which is smaller than the PS/2 form factor, to fit with <500 Watt PSUs. Yes, I'm aware of uATX PSUs, but they're hardly that easy to find or in large selections.
What are your thoughts on CPX? Would you use a CPX PSU and compatible case for your new system?
