WuTangClam said:This might sound like a silly question, but have you been using the gigabyte flashing tool to flash or flashrom? The gigabyte tool is the key to unlocking the disabled pipes.
Not a silly question, forgot to state that.
GVF11 states "This is an ATi Card"
I had to use -f to force it.
So that means that Powercolor is using ATi as an OEM for their cards.
So that means it's probably laser cut.
are the traces too small to bridge with tiny bit of solder?
-Ed
