i'm thinking about building a new pc and i need some advices
im thinking about buying the new pc either before summer or after summer
i have been looking around and thats what i found so far...
video card- EVGA GeForce 8800GTX 768MB - $649.99
mobo- EVGA LGA 775 NVIDIA nForce 680i - $249.99
or
ASUS P5N32-E SLI LGA 775 NVIDIA nForce 680i SLI ATX Intel Motherboard - $239.99
cpu-Intel Core 2 Extreme QX6700 Kentsfield 2.66GHz - $970.00
ram-CORSAIR XMS2 2GB (2 x 1GB) - $155.99
hdd-Seagate Barracuda 7200.10 400GB - $119.99
case- COOLER MASTER Stacker 830 Evolution - $259.99
power supply- OCZ GameXStream 700W - $139.99
or
Thermaltake 700W- $164.99
all of it adds up to about $2500, and i would like to spend about 2000-3000
i heard that after april 22nd there will be a major price cut on cpu, so im sure i will wait for that
and here are couple of questions about that setup
1. will there be any other major price cut on any of the parts that i want to buy in next 3-5 months?
2. i heard that qx6700 is not very good choice, because its not fully quad core and it doesnt use its full power, so i was thinking if intel is going to release more quad cores in next 4-5 months?
3. i've been looking at couple of geforce 8800gtx video cards and some of them have 575mhz core clock and other have 625mhz, is there really a big difference between those two?
4. do i need a water cooling system for the setup that i want to buy? or would 7 120mms fans be enough to keep it cool?
5. is 700w will be enough to run this setup? and in the future im also thinking about buying another video card and 2 more gb of ram
6. is there anything that i should change or add in my setup?
i would really apreciate if someone could help me, ebcause im really confused about what i should do
or
or
