Unless AMD releases threadripper/naples - on the same AM4 chipset as Ryzen --- that consideration is not comparable for AMD. Is Naples releasing on the same socket chipset as Ryzen? I was under the impression no...
So, no TDP for the 12c or more chips and turbo is not the all core turbo speed. I sense either stupid tdp or low clock speeds coming our wayIntel prices released.
https://www.hardocp.com/image/MTQ5NjE0NDMwMzhka21lcWYwY2FfMV8xX2wuZ2lm
Ryzen 1800x has some competition in the I7-7820x.
Yes Ryzen 1700, 1700x, and 1800x will be cheaper - but you can pretty much bet that Intel part will hit 4.5Ghz across all 8 cores with decent cooling on an overclock, and with IPC's being 20-30% faster on Intel, and with a 10% + overclock advantage -- that's 30-40% faster for a couple hundred more bucks. Probably worth it to most people.
I'm tuned in to what threadripper brings to the table for the price, but Intel, as expected, isn't just going to let AMD have a free and clear win. Unfortunately AMD's position is still limited to "for the price"
AM4 will be supported for at least 5 years. Something Intel has never done. Good luck thinking i9 88xx will run on X299.
Word is that AMD's Threadripper lineup has 44 PCIe lanes across the board. If that's the case, they've already eaten up Intel's HEDT lunch in my book, because most people who need the lanes aren't gonna blow $1,000 on just the CPU.
NVMe SSDs galore, 10-Gigabit Ethernet NICs, multi-controller USB 3.0 cards, perhaps even Thunderbolt 3.0 controller cards, video capture/framegrabber cards that can handle high refresh rates - there are a whole lot of things that are not GPUs which warrant more PCIe lanes, particularly with the rise of NVMe, and the more of them you have, the readier your system can be for future expansion.
I'm hoping AMD capitalizes on that.
16/32 Threadripper is probably going to be $1000
Apparently here is a heatsink for Threadripper. That thing is comical in size.
Part of the cost of the X299 and X399 motherboards will derive from the structural reinforcement they have to keep from warping under a five pound heatsink!
Stupid TDP is my guess, 200W incoming, you will need a platinum 500W PSU just to power your CPU, I thought we were beyond those days. I am actually upset about two things with Intel.
sarcasm is not the strong point but either way we know it is likely going to be higher than 165W also, maybe if we take the difference between the two will be the likely TDP
Rysen is currently a flop in datacenters.
We have 3 server vendors...none of them has any servers on their roadmap.
A product needs to be purchasable in order to get any "success"...and again, I am talking about vendor roadmaps...forget about actual products.
You realize Ryzen isn't even a server class CPU right? Those are coming. And in 3 years when I'm due another refresh I hope to have AMD cpu's in the running!
AMD will price their 10-core RTR chip to compete with Intel's 8-core offerings. So yeah, the new i9 8-core chip is good, but I prophecize that AMD will bring out their 10-core RTR within $20 of the i9; with 64 lanes PCI-E and a soldered IHS.
Maybe, but the TR mobos are expensive and quad-channel high-speed memory is not so cheap; the overall system price difference will be smaller than for the CPUs alone. Soldered IHS didn't help RyZen to break the 4GHz barrier with easiness, and why the new motto seems to be "moar lanes"? Has it definitively replaced the "moar cores"?
Intel fanboys used lanes to sell themselves on X79 and X99, but once AMD has the advantage, suddenly they aren't important: brilliant irony.
And to answer your question: 2 GPUs at 16x bandwidth uses 32 lanes: already more than the intel solution's capabilities. And we are seeing modern engines capable of saturating 8X PCI-E 3.0, so running two GPUs at 8x is not ideal. Add in two NVM-Express drives, a nice AC wireless card or video capture card, maybe a SAS raid card with BBU... the poor little intel 8-core cant handle all that, meanwhile the AMD is barely half full.
I didn't say they aren't important. Simply stating my surprise on how suddenly number of cores, stock clocks, OC capabilities, IPC,... lost importance. All what matters now is the number of PCI lanes.
About ironies I know some of them, such as certain people dismissing efficiency in the Builldozer/Piledriver era, "it is not important" they said, "nobody cares" they said, and then forgetting all what they said whereas repetitively mentioning "95W vs 140W" and pretending that RyZen was going to be much more efficient than competence. Or what to say about all the emphasis on the classic "moar cores". Moar cores was mentioned by some people when they believed it was going to be a 16C vs 12C fight. Now it is confirmed it is 16C vs 18C, the emphasis has shifted to "moar lanes".
Bottom Line: Intel wouldn't have never released a consumer CPU with 18-cores (or even one with >12-cores) if Threadripper hadn't been announced.
Official rating is 180W for current Threadripper samples, which equates to >200W real.
In addition, the reason why the specs for the 12-18-core Skylake-X chips haven't been set yet is very simple...Intel is waiting for the detailed specs on Threadripper before setting them on the HCC Skylake-X chips and will aim to match Threadripper's feature set as much as possible...nothing more...nothing less. If Intel had its way, it would neuter the HCC Skylake-X chips to the ground...
There is no HCC SKL-X chips. There are LCC and MCC.
This strategy from Intel is derived from what they call internally as their ‘LCC’ core, standing for ‘low core count’. The enterprise line from Intel has three designs for their silicon – a low core count, a high core count, and an extreme core count: LCC, HCC, and XCC respectively. All the processors in the enterprise line are typically made from these three silicon maps: a 10-core LCC silicon die, for example, can have two cores disabled to be an 8-core. Or a 22-core XCC die can have all but four cores disabled, but still retain access to all the L3 cache, to have an XCC processor that has a massive cache structure. For the consumer HEDT platform, such as Haswell-E and Broadwell-E, the processors made public were all derived from the LCC silicon.
Thanks for sharing your benevolent nitpicking with everyone...you'd better scurry off and correct half the internet, starting with Anandtech...
http://www.anandtech.com/show/11464...ng-18core-hcc-silicon-to-consumers-for-1999/2
Here's a quote from their opening page:
So...LCC...HCC...XCC...
Anything else you care to pick at?
The new Skylake-X models employ the Skylake Xeon HCC, MCC and LCC die.
There is no such thing as XCC. There is LCC(10C), MCC(18C) and HCC(28C).
And if you want some article not saying XCC.
http://www.tomshardware.com/news/in...by-lake-x-x299-basin-falls-core-i9,34545.html
Anand sure sold at the right time.
Wow a lot to take in here . Some good & some bad, but all in all good conversation. I think I'm going to get threadripper. Even though i got my the 1800x on launch. I'm going to try and water cool it. And i'm going to try to get Vega to go with it. Very interested in the AMD ecosystem. I just need new hdd and a case to go with it and a pricing plan. Here my thought on a Build. Just a speculation on the things that have no price at the moment
CPU Threadripper 16c/32t at around $1000 -$1200
CPU Cooler Custom watercool block $100
Motherboard ASUS X399 ROG ZENITH EXTREME $600
Memory Dominator Platinum Series 64GB (8 x 8GB) DDR4 DRAM 3200MHz C16 Memory Kit $799
Storage SAMSUNG 960 EVO M.2 500GB NVMe PCI-Express 3.0 x4 Internal Solid State Drive $250
Video Card Vega $800
Case Red Harbinger Dopamine Case $350
Power Supply MasterWatt Maker 1200 Digital Power Supply All-Aluminum 80PLUS Titanium $430
This is my base then will build a custom water cool loop with monsoon fitting...
Any thoughts? Also love to hear if anyone else is going to upgrade to Threadripper or Intel new i9.
