let us know how it does, if its anything like the 0608, it should rocktvdang7 said:WTF mine jsut came its a new one!!
165 CCB1E 0609 FPMW
any one have this one?
i wanted another 0610!!!![]()
In general, CCB1E > CCBBE, be happy, might be a gem.tvdang7 said:WTF mine jsut came its a new one!!
165 CCB1E 0609 FPMW
165 CCB1E 0609 FPMW
tvdang7 said:at 2.7 ghz stock voltage temps around 37-39 water of course. still priming
jcll2002 said:maybe because high end air is as good as low end water... may be the case
tvdang7 said:MP-05 SP
maze4 gpu
swiftech mcp655 pump
BiX2 with 2 77cfm fans
i hope thats not low end is it?
tvdang7 said:im as clueless as u are i just read on stickies on whats pretty good and bought it. for all i know its leaking water right now hahahah
maze4 gpu
aldy402 said:you have a good HI-FLO setup
not everybody's temps are gonna be the same. There are too many variables to do direct comparisons. You have to take in effect of how long your pc's been running, ambient room temp, ambient case temp, additives in your water, the amount of exhaust fans u have running the case, the CFMs of the fans you have on your rad. where the rad is mounted etc etc. I could keep going on and on but you guys get the point dont you? and different steppings have been reported to run hotter or cooler then others.
btw tvdang, you have ur bix2 mounted externally? does it sound like a jet engine with 2x running at 77cfms?
n19htmare said:I get 38 max on BT Air cooling... 2.8Ghz and 1.37V.... why are your temps same as me on air while youre on water?
yeah i have a feeling my ultra d is within 5c too lowburningrave101 said:Because you probably have a DFI board and your temps aren't accurate. People shouldn't put much weight into the temps their boards are reporting because almost every board reports higher or lower then what it is actually. The DFI NF4 Expert currently reports around 8-10C+ lower then actual temp.
jcll2002 said:my ccbbe 0619 does 2.8 stock vcore... (1.32) Idles @ 30cLoad is at low 40s
tvdang7 said:thanks guys. i hope its good. trying to do the dual core fix......my CSS crashing instantly.......sigh....plus i have finals to study for!
I never had any problems with CS:S or HL2, but I did have some major benny hill effect problems with CS 1.6 till I set the affinity to 1 core.KingPing said:I was having problems with my CSS as well......I just set it to run on 1 core and it runs flawlessly now![]()
trikat said:Are these codes limited 1 per person/address, because I wanted to get 2 and it says coupon expired on the 2nd try. I have my opty 165 coming tomorrow hopefully.![]()
amd ati FO SHO said:no they aren't
Retsam said:Uhhh yes they are AMD ATI FO SHO. THey are limited to 1 use per address/person/zipcode. Im not really sure what they go by. But yes, they are limited to 1 per person. Always have been. Hence why it says expired after you use it once.
amd ati FO SHO said:how are people buying multiple chips then? if you have been paying attention to this thread theres people buying and reselling these chips
mrbay said:Anyone know what stepping is being shipped out now?
what info do you need?dab12 said:monarch man we need the info
its still a gamble as I just got my dud ccbwe 0607upbwmrbay said:Anyone know what stepping is being shipped out now?
