thanks.burningrave101 said:As long as you dont go much over like 1.5V then the processor should have no problem lasting 2-3 years overclocked. Its when you start getting up in the 1.55V+ range on a 90nm CPU that normally runs 1.35V that it starts really cutting down on lifespan. I would try to keep it around 1.45V or under though and see if you can't get close to your max clock with that.
