Zarathustra[H]
Extremely [H]
- Oct 29, 2000
PCGamesN is reporting that AMD has vastly improved memory compatibility with the Ryzen 3000 chips after admitting this was a weakness in previous iterations. The X570 Godlike has demonstrated 5Ghz RAM speeds, and 4200mhz has been accomplished with other boards by simply tweaking XMP settings...
...but, you may not want to go all the way up to the fastest clock you can hit. Reportedly the real memory clock sweet spot on the new infinity fabric is 3733Mhz for best latency.
Sounds promising!
Sounds promising!
