delita
- Mar 10, 2014
can i buy this yet to go with my new titan-x geez acer get on it
Subscribed... I'll be watching this as well.
That was exactly my thoughts. How the hell to drive 3440x1440 144Hz. 5 megapixels.
VRAM speed will be very important. Three Titan X's!
Acer is not going to release any info for a while. They do not want to steal sales from their 27" Predator model that just started shipping.
I hope this will have a VA panel, I've read good things about the new samsung panel for example.
I wonder if it can be overdriven fast enough for good strobing (or decently low blur in gsync mode).
That would make it the first challenger to the FG2421!
I am not that optimist with the 34" VA panel from samsung:
heavier matte coating than LG IPS
outputs 58 cd/m² at 0% brightness. compare that to 15 cd/m² of the dell 3415
sRGB coverage is sub par for a 2014 VA panel.
on the plus side it comes with a VESA mount , has very low input lag and good overdrive results in standard mode. I do consider it expensive at $1200, a price range of 32"-40" 3840x2160 screens.
I have a pre-order in for the XB270HU, but now I'm thinking I might hold off for the XR341CK. As someone who can't stand narrow FOV, does 21:9 have a naturally wider FOV vs 16:9 at a given games default FOV setting? In other words, will I still need to rely on Flawless Widescreen or Widescreen Fixer is increase the FOV?
I'd rather play 16:9 with bars than get added input lag with scaler.
It's worrying that there isn't any news about this monitor...
I don't think this is going to fit on my current monitor stands. They're made for monitor's up to 28". Anyone know of any hex stands that will be able to fit this beast?
I am using the Dell MSA14 with the Dell U3415W, which is also a 34" 21:9. The dell arm is also does not mention support for screen over 28". Just check whether or not the weight of the monitor without stand is supported by your monitor arm and you are good.
I need a hex stand or clamp, a single arm will not work for me. The top row has to be able to fit 2 24" screens and the Predator.
I'll be getting rid of the one on the top right, putting the Predator in the middle, and shifting the other screens around.
If this thing isn't VESA mountable I'll be pissed.
